10-09-2022, 05:08 PM | #1 |
Rep 1
530e home charging set up
Long time lurker, first time poster. I'm looking for advice on what to purchase for a home charging set up for my soon to arrive 2023 530e. I'm going to have an electrician install a 240 volt line for a level 2 charger because I plan to do a lot of electric driving. beyond this I don't know what charger model to buy and whether portable or wall mounted is better in the long term. Any advice as to what I should order ? Thanks
10-09-2022, 07:11 PM | #2 |
866
Rep 611
It depends on what you are looking for in terms of connectivity, information, and control. I would recommend leaving your level 2 charger connected and not unplugging it all the time with a portable. The NEMA connector gets loose from all the plugging and unplugging cycles which can become a hazard. Just connect it once with your desired charger and leave it connected. As for the charger, you can go a little cheaper and get a dumb one. It essentially turns on when connected to your vehicle and turns off once you disconnect. There are "smart" ones such as the Chargepoint that has an app that allows you to turn the charger during off peak hours to reduce charging cost if your provider has different rates during different hours of the day. It will also let you know how much you charged during your sessions, etc.
10-10-2022, 10:15 AM | #4 |
248
Rep 538
The one above is fine for the 530e. Key is to have the same plug and socket on your 240v. setup to be installed by electrician. If you are contemplating going to a full electric EV at some point in the future and are going to be in the same house, suggest you go for an EVSE (what you are calling a "charger") with more capacity. 9.6 KW is optimum, but that will require a 50 amp service connection. I suggest the Canadian Grizzle-e. Worked well for me and less expensive. You really didn't include enough information for a recommendation.
10-10-2022, 12:43 PM | #5 |
3086
Rep 4,210
What are your longer term goals? Is the 530e a stepping stone to a pure electric car? BMW has annoyed me by putting the charging port on the front driver side fender on the PHEVs but on the rear passenger side for its pure electrics. Really stupid in my opinion if they want to keep folks in the BMW universe (I plan on a pure electric for my next car and as of now it is not a BMW...too ugly...but a Lucid Air which incidentally has its charging port on the same side as the 530e.
My point is that if you are planning on a pure electric you need to think about where to put the EVSE Perhaps think about what company will likely be making your first EV and see where they put the port and determine if there is a way to fit both without having to subsequently relocate the EVSE. Most do come with a fairly long cord. |
ted99248.00 |
10-10-2022, 03:21 PM | #6 | |
22
Rep 59
I'm looking to trade the 530e for the new i5 M50 when it's released so the Grizzle-e will future proof my set up.
2018 G30 530e M Sport - MGF Stage 2, Catless DP, 6WB retrofit
2018 Audi FM Q7 - APR Stage 2 SP, BMC/Roc Euro Intake 2014 F10 550i M Sport 2008 E60 M5 2005 E46 M3 |
10-10-2022, 03:25 PM | #7 |
80
Rep 116
That Amazon 32amp charger is all well and good but your 530e is only able to receive 16 amp max. My recommendation would be to get a wallbox charger and let your 530e send it all the instructions. I have a 545e and when I first purchased I had awful time getting used to it. I made the mistake at the beginning asking the car and charger to send the same instructions at the same time......that didn't work. It's either the car or the charger sending the instructions, not both.
ted99248.00 |
10-11-2022, 02:24 PM | #8 | |
325
Rep 436
I disable it all at the weekends for now, via the app(s) on the phone. |
10-11-2022, 04:53 PM | #9 | |
80
Rep 116
04-17-2023, 02:26 PM | #10 |
51
Rep 57
Drives: 2020 BMW 530xe
Resurrecting this not too old thread, I just bought a 530e, and the Grizzl-E looks like a nice charger, I think I'd just use the app to set my charge and preconditioning together, so it looks like the Classic would fit that. To future proof, I would just have the 50A service installed for it, even though I know the 530e can't really take advantage of that, but that will future proof me to a degree. My mother has the Chargepoint for her Volvo, but give the BMW app appears to let me do everything in terms of timing, I do not see where the added cost for that charger, or the ability to go to a 60A breaker to get 37.5kwh gains me anything.
I know with the Chargepoint we removed the NEMA whip and hard wired it, I'd rather do that instead of installing a plug next to the charger, anyone just hard wired their Grizzl-E? |
04-19-2023, 02:57 PM | #11 | |
714
Rep 2,607
Drives: 06 330i E90, 18 530xe G30
