Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > 2009 BMW 328xi oil drain cap
      10-01-2022, 12:31 PM   #1
e90N00b
Drives: 2009 BMW 328xi
Hello I'm trying to do an oil change on my 2009 bmw 328xi (xdrive) but I can't seem to find the oil drain cap. The underbody looks different than what I've seen online. I'm unable to find the panel that reveals the oil drain cap so I'm thinking the whole pan might be gone forever.
I see one thing that looks like it fits a 17mm socket but I odn't want to touch it unless I know it's the oil drain cap for sure. Attached are pics of the underbody with what I think is the oil drain cap.
      10-01-2022, 05:40 PM   #2
Pittz1
2018 M3 ZCP / 06 330xi
211
Drives: 330xi 2006 / 18 M3 ZCP
I dont think you should be doing an oil change if you can't find the plug. Its staring right at you in the first picture.
      10-05-2022, 08:32 AM   #3
Suvorovo
Suvorovo's Avatar
254
Drives: Broken e90 330xi 6MT
He's an e90 noob. Cut him some slack!
You should probably use a torque wrench for your oil plug given your lack of experience. Don't strip out your aluminum oil pan drain hole.
25NM/18ft lbs.
Don't confuse NM/ft lbs measurements on the torque wrench.
      10-05-2022, 10:05 PM   #4
NorthernDancer
850
Drives: 08 Sedona 128 & 06 330xiT 6MT
Well I don't see it altho I'm more familiar with E82. My E91 is new to me and I haven't done an oil change on it yet but I do have a picture of where it is-it's behind a small access "door", the same as the E82.
There does seem to be a pretty good oil leak from somewhere. If it's the oil filter housing gasket, that's a time bomb just waiting to happen and likely within a year.
Suggest you get your car looked at by a good BMW indy garage.
