09-23-2022, 07:59 AM | #1 |
///M ♥ Recycled Dinosaurs
3212
Rep 1,781
Drives: BMW M4, BMW X5 45e
What tire pressures do you guys run?
Temperatures are starting to fall off here and yesterday taking a corner hard I could feel the rubber band effect on the rear tires after the cornering ended and the rear "bounced" back.
This is always an indication for me that the tire pressure is too low causing sidewall flex and bounce back. And sure enough, it had fallen down to 34 psi. Now this is around what BMW recommends but I feel like they are pushing for a soft ride over handling. My gut feel is that the fronts are fine/best at the recommended pressures but the rear is best run at around 38 psi. What pressures do you run? Do you have similar thoughts on this? I run Michelin PS4S on 963Ms.
2022 BMW ///M4 Comp M xDrive (Enzian, Kyalami - insta | youtube | bp featured: Delivery + 963M + 2x Enzian!) | 2021 BMW X5 45e (Carbon Black Metallic, Ivory White)
BMW CCA LIFETIME MEMBER | Past cars: 2016 BMW 435i Gran Coupe (Carbon Black Metallic, Oyster White - Euro-delivery) |
09-23-2022, 08:06 AM | #2 |
1858
Rep 2,306
I use the BMW recommended pressures.
2001 330Ci (sold)
2007 335i (sold) 2008 E90 M3 (sold) 2015 M3 (sold) 2022 G83 |
09-23-2022, 08:23 AM | #3 |
4844
Rep 2,744
Just make sure it's not 1.5psi too low
18
jimbethesda1857.50 kjx3211.50 bri10426055.50 chicagofan0019255.50 2011ninja3412.50 FISH225413.50 Purekoryo518.50 Tall Tom Cruise1006.00 njfoses290.50 BTC Maxi416.00 wavyyyy1046.50 Rodizzle410.50 Bostro531.50 geko291575.00 Roth517446.00 An20Olives80.00 Slowlives307.00 Alpine300zhp1453.50 |
09-23-2022, 09:17 AM | #4 |
458
Rep 328
I use the BMW recommended pressures via the drivers side door sticker....
2023 M4 Comp
Dravit Grey Metallic |
09-23-2022, 09:32 AM | #5 |
349
Rep 143
kjx, this is (has been) my setup history, and the car didn't explode yet Seriously, I always had a safe driving experience with these setups:
May 2022 after driving home from dealer: Front: Michelin PS4S | 275/35 ZR19 (100Y) XL 2,7 bar (39 psi) at 37°C (98°F) on 9.5J x 19 H2 [825M] Rear: Michelin PS4S | 285/30 ZR20 (99Y) XL 2,8 bar (40.6 psi) at 34°C (93°F) on 10,5J x 20 H2 [825M] No pressure correction made since then. 3 days ago: Warning "check tire pressure" on the display at the dashboard: 4x 32 psi (recommended: 4x 36 psi) at 72°F Now driving at 72°F 4x 37.7 psi | Recommended: 39 psi NOTE: Temperatures as indicated in the car's menu, NOT environment temps! Last edited by Joachim; 09-23-2022 at 09:43 AM.. |
kjx3211.50 |
09-23-2022, 01:01 PM | #6 | |
3413
Rep 2,639
30 psi cold test; all 4 tire's; Pirelli zero Temperature has dropped Works for me |
09-23-2022, 01:07 PM | #7 |
1552
Rep 17,395
During summer I run about 33/34psi measured when tires are cold. It gets up to about 36/37 when driving for some time.
During winter I increase to 35/36psi and it gets to about 38/39 when driving for a bit. I'm on 4s also. |
09-23-2022, 01:55 PM | #8 | |
236
Rep 323
Intrigued why you go up in pressure in cold. 32psi would be a different relative pressure depending on temperature as air density changes. I always inflate mine to 2.2 bar all round as per plate in car for whatever the temperature is outside. Regards David |
09-23-2022, 02:27 PM | #9 |
3212
Rep 1,781
If I'm counting right, we have 6 different preferences for 7 people. Lol.
09-23-2022, 02:50 PM | #10 | ||
1552
Rep 17,395
I pulled this from tire rack https://m.tirerack.com/tires/tiretec...jsp?techid=168 Maybe I'm doing it wrong and open to suggestions but I was always taught this way. |
Joachim349.00 |
09-23-2022, 08:53 PM | #11 |
519
Rep 456
Drives: G80 M3 Competition
You guys run these too high imo.
PS4S run best at 33-34 psi HOT for best grip and steering feedback (I know it's almost non existent in our cars but it does make a noticeable difference to me). |
09-23-2022, 09:03 PM | #12 | |
3212
Rep 1,781
34 psi cold in the front is good. Good steering feedback, soaks up bumps, etc. I don't really care about the front - it's very forgiving for a range of pressures. I don't take it down to 30-32 because that's lower than what BMW recommends in the car/app and what they recommend for the front works for me. Maybe I'll try it anyway. 34 psi at the rear is definitely not good for me because I can feel the squishy feedback at the back on rapid changes in direction near the limits where oversteer can start.
09-26-2022, 01:40 AM | #16 | |
BMW forever!
1392
Rep 2,425
2020 BMW X5
2019 BMW M2C 2014 BMW 335i 2009 BMW 328i |
kjx3211.50 |
09-26-2022, 02:10 PM | #17 |
809
Rep 980
I'm like 33-34,35 in fronts and rears run like 35-36 but vary obv
2008 E60 550 ? Alpine White // RPI
2011 E90 M3 Competition // Alpine White // ESS // RPI // 20" BBS LM's, blah blah 2021 G80 M3 Competition // Brooklyn Grey // KW Suspension // 12mm Spacers all around // Resonator Delete |
kjx3211.50 |
09-26-2022, 03:10 PM | #18 |
1006
Rep 570
Here's an additional data point:
Cup 2's: 33 front, 35 rear Southern California and 60-80 degrees all year |
kjx3211.50 HudsonHornett1258.00 |
09-26-2022, 04:06 PM | #19 |
18830
Rep 14,134
Drives: G82 M4C X-Drive
It depends on the tire, but generally what is recommended on the door jam is the COLD pressure. However, the overall better measurement is the HOT/OPERATING recommended pressure for your car's weight and driving style. That is determined by the wear on the sidewall. You can measure this by marking all 4 tires with chalk, going for a drive that represents the conditions you want optimal pressure for, then looking at how much of that chalk is getting rubbed off. Start low, and work your way up until you get minimal wear on the sidewall. Too much wear, and the pressure needs to go up. If you want to get super exact, measure the temperature across the tire contact patch and see if temps are too high on the edges (you can check camber this way too).
Of course, no one is going to do this on the street, it's unnecessary. This is what you do on the track to get the optimal pressure. That being said, the "bounce back" you are experiencing is unlikely due to the tire pressure, and more to do with your dampening settings in relation to the road conditions. You are perhaps on sport + on the streets rather than just sport. Just stick with the cold pressures. You can also look up each tires optimal hot/operating pressures online and adjust when they are hot.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
09-26-2022, 05:21 PM | #21 |
18830
Rep 14,134
39 is way too high for rears warm for me. Most of your heat is going to be front for cornering unless your doing donuts! 35 warm in back is the highest I would go for high performance driving on the *MPS4S.
FSociety3812.50 |
