08-09-2022, 10:00 AM | #1 |
3372
Rep 22,756
getBMWparts.com | Dinan Carbon Fiber Turbo Inlets for B58 & B46!!!
getBMWparts.com | Dinan Carbon Fiber Turbo Inlets for B58 & B46!!! Turbo inlet pipes serve 2 very distinct, and differing, purposes. On one hand the optimization of a turbo inlet pipe will encourage better turbo efficiency and responsiveness by allowing the turbo to ingest more air by way of an unobstructed and larger volume flow path. On the other, you have a more visceral benefit that some may argue is equally, or even more, important than that of efficiency/flow optimization --- increased sound. No matter which of the distinct purposes is favored, Dinan will deliver on both. No matter the application, a Dinan turbo inlet replaces the weak, and failure prone, plastic factory inlet with a more robust carbon fiber one. CNC machined fittings are utilized to ensure proper fitment and guarantee installation as a direct replacement to the OEM inlet. Beyond material and fitment however are the improvements to the characteristics of the primary element in the system, the pipe itself. The stock turbo inlet has incorporated additional features (multiple in some cases) that introduce flow restrictions and turbulence while also reducing turbo noises. All of which are unwanted but easily rectified by removing the various resonators and enlarging (and optimizing) the path for a more uniform flow. The result is an inlet that delivers not only more air and allows the turbo to be more efficient (work less) but also provides the oft desired amplification to the turbo induction soundtrack. Features & Benefits:
Evan Winstead · Internet Parts Director
Contact Us | Facebook | Twitter | New: Shop Porsche & Audi parts! |
Tags |
carbon turbo inlet, dinan, dinan carbon inlet, dinan inlet, dinan parts, dinan turbo inlet, getbmwparts |
