335 xDrive - Bilstein B14 Coilovers Installed Pics & Feedback
07-29-2022, 06:20 PM | #1 |
Rep 15
I Figured I would post a quick write up of my thoughts on the B14 coilover kit for xDrive
I had previously read that some people had issues with the rear sitting low. As well we know the issue with negative rake on these cars. Im very happy with this kit and how it turned out. Maybe this can help someone in a similar position trying to decide Initial setup: Eibach RWD springs and stock shocks. Car sat low enough for me but with some negative rake. Stock worn shocks drove pretty bad in retrospect. Lots of hard bottoming out. The front strut mounts were pretty compressed as well with 100K miles on them B14: Much more equal drop front to rear. Drives solid. no more bottoming out. I really dont have anything negative to report Bilstein B14 # 47-269095 Front Top Strut Mount Bearings Front Strut Carrier Gaskets / Pinch Bolts Rear Spring Lower Shims / Bumpstop Cups / Sealing Grommets Rear Shock Mounts Upper (Monroe HD) Rear Shock Mounts Lower (Monroe HD) Also did Z4 2pc front rotors, pads, painted the calipers, and pressure bleed Some random pictures below and showing the ride height ** I went full drop in the front and fully raised in the rear I live in Michigan and most of the roads around here suck. The car is way more forgiving
2011 BMW E92 335i xDrive / M-Sport / 6-Speed
- AFE DP / BMS Intercooler / CP / NGK 97506 - Spec Stage 2 / Mid-Cat Delete / PE Mod - MHD S2+ / Water/Meth Inj. |
08-03-2022, 11:55 PM | #3 |
28
Rep 488
Drives: 2008 335xi E90
How does she drive?
08-04-2022, 04:36 PM | #4 |
Rep 15
I love it. Soaks up the hits on crappy roads way better then the stock high mileage shocks. Night and day really
I have no negatives considering the car is a daily driver
08-04-2022, 04:37 PM | #5 |
Rep 15
Nice! Are the E91's quite a bit heavier in the rear? Just wondering
08-12-2022, 09:23 AM | #6 |
144
Rep 776
08-12-2022, 09:26 AM | #7 |
144
Rep 776
I've been watching a couple of install videos as I'm planning on doing this myself. Did you need any special tools, especially Part B in the front strut diagram? Some videos show a special strut nut socket when installing the coilover. Just wondering if I need to purchase that.
08-17-2022, 05:21 PM | #8 |
1169
Rep 1,480
Drives: 2008 BMW 335xi (E90)
Where at in Michigan are you? I'm looking at my options to change up suspension and would love to maybe take a ride.
I'm in the Kalamazoo area.
Instagram: @4doors
Current: 2011 E91 328i M-Sport Touring Past: 2008 E90 335xi 1996 E36 328i Sport |
fazm616.50 |
10-02-2022, 09:35 AM | #10 |
144
Rep 776
Finally got the B14s installed on my E91 last week and I'm loving the ride quality so far! I can feel that it's a tad bit stiffer than stock not much of a compromise for daily use.
04-13-2023, 10:24 PM | #12 |
80
Rep 151
Definitely plan on getting these for my e91 as well, and plan on adding ground control camber plates to the front to get it dialed in perfectly
