Car wobbles when brake pedal is released
05-08-2006, 04:35 PM | #1 |
9
Rep 147
When I come to a full stop, put it in park, then take my foot off the brake, the car "wobbles" back and forth...and quite noticeably. Anyone else notice this? I've never been in a car where it was this apparent...
2017 540i MSport
2014 535i 2011 335i 2006 330i |
05-08-2006, 04:49 PM | #2 |
8
Rep 252
Drives: ordered blk s 330 sp, pr, cold
Make sure you lug nuts are tight. Did you have anything done on the wheels as of late? Shouldn't be doing that.
05-08-2006, 06:52 PM | #6 |
155
Rep 6,158
guarantee that's the issue
if I remember I think the torque converter disconnects at idle on the E90, so when you don't use your parking brake the car may be just like leaving it in neutral (don't quote me on that) maybe try pushing your car after you park it and put it in park and see if it rolls most normal automatics don't do that so lots of auto drivers don't use their parking brakes and are just fine. |
05-08-2006, 07:58 PM | #7 | |
39
Rep 647
05-08-2006, 10:10 PM | #8 |
99
Rep 990
kungfujoe,
If you are talking about what I think you are, then your car 'wobbles' back and forth only once or twice, then stops, right? If so, I would say that this could be considered 'normal'. My car did it when it was new. It irritated me to the point that I went to the dealership and drove another 3 for comparison. Sure enough, that test car did it too. I think they mostly do that when they're newer. I haven't noticed my car to do it in a while now, and I occasionally do try to pay attention for it at stop signs/lights. If I had to guess, you'll notice it start to lessen after a thousand or two miles. It's no biggie. |
05-09-2006, 06:23 AM | #9 |
Rep 61
Try this and see if it goes away:
Come to a stop. Apply parking brake. Remove foot from service brake (that is the brake pedal). Put car in park. Any better? If so what you are experiencing is probably the park pawl. |
05-09-2006, 06:40 AM | #10 |
Sheer Driving & Biking Pleasure
19
Rep 223
Drives: 318ti compact E36
I read this thread, because Iīve got the same "problem" with my E46-Coupé...but Iīll try it also once again by using the hand-break before put in P-position.
One thing I find also strange: For ex. if I start the engine (P-position) and would like to drive, than I normal go from P to D - at this procedure the Gear-lever is going only with strong of pushing down in D-position! But if I go back from D to R or P, itīs nevertheless given this problem...is something damage in my automatic-gear!?
"...weīre from Bavaria, itīs near Germany..."
Greets, Flo Mountainbike: CUBE Stereo EX-CARīS: Ford Fiesta 1.1 | Nissan Primera 1.6 SLX | 318ti-E46 | 320dT-E46-FL | 120d E87-Pre-FL | Skoda Oē Combi 2.0TDI Elegance | 325CiA E46-Pre-FL | Ford Focus I Turnier Sport TDCi |
05-09-2006, 07:05 AM | #11 |
1312
Rep 10,185
Come to a complete stop via the foot brake.
Apply handbrake Put car into Park Switch off engine Always works perfectly for me
BMW if you are reading, I need a job, Please. |
05-09-2006, 07:10 AM | #12 | |
1312
Rep 10,185
Are you saying in your E46 it is hard to move from P to D when you first start the engine, but it is then easy later ?
05-09-2006, 07:17 AM | #13 |
19
Rep 223
@E90Fleet: Yes, I absolutely mean this situation - itīs happening very often from P to D, but never the other way back.
But thereīs nothing given differences, when the engine stands over night or was driving a time before.
05-09-2006, 07:51 AM | #14 | |
1312
Rep 10,185
Dealer would have to check if it is just the shift knob, a connection or the gearbox. Maybe something just needs a bit of oil because it sticks when cold
05-09-2006, 08:00 AM | #15 |
19
Rep 223
@E90Fleet: Thankīs for the oil-tip, at next service Iīll say it
to my mechanical man, I think, itīs not a big problem.
05-09-2006, 01:11 PM | #16 |
9
Rep 147
But what is causing this? It's pretty apparent and I don't recall noticing it on my wife's SUV, which is an auto.
Even if I apply the hand brake, when I release the foot brake, it still wobbles a little.
2017 540i MSport
05-10-2006, 06:32 AM | #18 | |
Rep 61
