2013 E92 335xi Key fob won't unlock
07-03-2022, 12:00 PM | #1 |
Rep 2
2013 E92 335xi key fob won\'t work
I'm trying to get my key fobs to work but neither of them are locking or unlocking. I replaced the batteries on both. The central locking system on the console works just fine and I'm able to use the physical key to lock and unlock. I checked the fuses to see if anything was blown but all of them are working and looks fine. The fuses for door lock actuators are 61, 72, 73, and 79. I replaced 72 and 73 with 20A fuses, 61 and 79 is still working when I test it with light. Any suggestions?
07-03-2022, 12:13 PM | #2 |
1920
Rep 13,119
diversity antenna module and connections to it.
Most common cause when both fobs don't work. Since you have comfort access there is some possibility it could be that module also. There are many ytube on the diversity module trouble shooting and replacing it. If you have a convertible it has two sets of antenna's and up and down antenna. |
