Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > E92 right front suspension rattle
      06-28-2022, 08:36 PM   #1
jlegelis
jlegelis's Avatar
Drives: 2013 E92 N55 MT MSport
90k miles E92, recently developed right front rattle on crummy New England roads / potholes, but drives / brakes perfectly otherwise. Intuition says sway bar stuff rather than control arms, etc. Any common items to check? TIA!
      06-28-2022, 09:07 PM   #2
cbyrne
cbyrne's Avatar
17
Drives: 2011 e92 328i
2011 328i  [0.00]
xDrive or RWD?
Describe the noise, under what conditions it occurs, etc?
General advice is to get the car lifted up and make sure there is no play in the hub, no unexpected wiggle on any of the components. Put a wrench on all your joints/connections and check for proper tightness.
Impossible to be specific unless you provide more
@N52_e92 on Instagram
LCI 328i xDrive | 3-stage IM | AA catless headers | Turner Motorsport tune | 330i muffler retrofit | APEX EC-7 18x8.5 et35 square | Michelin PS A/S4 235/40-18
      06-28-2022, 09:33 PM   #3
jlegelis
jlegelis's Avatar
Metal-on-metal rattle when going over passenger side potholes only. Sway bar mounts perhaps?
      06-28-2022, 10:32 PM   #4
relative4
Drives: '08 335xi E90 MT stage 1+
14th century Spanish cutlass snagged on tension strut. You're rich!
      06-29-2022, 12:57 PM   #5
Cyril Sneer
152
Drives: E36 M3/4/5 / E91
Check sway end links first. Worn ones can make lots of noise even if they look ok. Also cheap and easy to fix.
