BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > 2009 328i xdrive sedan....no start
      06-15-2022, 07:56 PM   #1
Amber24019
Hmmmmmmm
Amber24019's Avatar
Drives: 2009 328i xdrive sedan (E90)
BMW 328 xdrive  [0.00]
Ok I see alot of people giving advice so I'm gonna give this a shot. Not a pro at bmw cars. Second one I have owned. 1st never Gabe any issues.
Ok so I have been having a few issues and I have read post after post on the no start. So after reading the things I have tried are as follows
Replaced the CAS RELAY in fuse box.
Ran a ground test motor is grounded.
Went through entire fuse box made sure all fuses were good.
I have disconnected the IBS sensor on the negative battery cable. Have since put back.
The only codes I'm getting are as follows
A0B4 CAS: ENGINE START/STARTER OPERATION
Now with that being siad and a new CAS RELAY DO I NEED TO PROGRAM THIS TO THE CAR???
USEING FOXWELL SCANNER NT510ELITE.
I HAVE AND OPTION IN SCANNER TO RESET THIS BUT GIVES WARNONG IT WILL ERASE DATA DO I DO THIS?
OR DO I JUST BUY A NEW STARTER AND TRY IT?
If anybody has any other ideas please respond. Would love to hear what you guys would try next.
      08-16-2023, 01:57 PM   #2
IghtCya
Drives: 2008 328xi
did you figure it out?
      08-21-2023, 11:03 AM   #3
Cyril Sneer
149
Drives: E36 M3/4/5 / E91
You're unlikely to get any answers here as your issues have nothing to do with the AWD system. Try reposting in the appropriate forum if still having issues.
