05-18-2022, 06:45 PM | #1 |
Joint Chiefs of Staff
4923
Rep 115,999
N54TUNING.com - Solo Werks S1 Coilover System - BMW F Series (F22 F30 F32) W/O EDC
Solo Werks S1 Coilover System - BMW F Series (F22 F30 F32) Without EDC now available @ n54tuning.com
ORDER LINK https://www.n54tuning.com/solo-werks...thout-edc.html Solo Werks S1 Coilover System - Premium Entry Level Coilover Suspension BMW 1 Series F20/21, 2 Series F22, 3 Series F30, 4 Series F32 12’-16’ Coupe / Sedan Lowering Range: Front- 40-65mm (1.6”-2.5”) Rear - 30-60mm (1.2”-2.4”) Features at a Glance: 3-Year Limited Warranty Warrants against Construction and Component Defects Heavy Gold Zinc Plated Housings Superb Corrosion Resistance, Salt Spray tested 500 Hours) Twin Tube Shock Design Gas Charged, Fixed Dampening, Independent Valves, App Specific Tuning High Tensile Chrome Silicon Wire Springs Light Weight, Less Stress, More Travel, Powdercoated Hardened Chrome Piston Rods Mirror Finished Elastomer Bumpstops with Dust Boot Micro Cell Poly, Progressive Rate, Long Life Span Height Adjustable Rear Perches Anodized Black Aluminum, Inc. Spanners Kit Contents: 2x Front threaded coilover dampers 2x Front Main Springs 2x Rear dampers 2x Rear adjustable spring perches 2x Rear springs Spanner wrenches Step by Step Installation Instructions 1oz. Bottle Boeshield T-9 Lubricant/Protectant Applications / Fitments: BMW 1 Series F20/21 11’-16’ without EDC Inc. M135i BMW 2 Series F22 14’-16’ without EDC Inc. M235i BMW 3 Series F30 12’-16’ without EDC BMW 4 Series F32 14’-16’ without EDC Notes: *All lowering ranges are approx. and will varying depending on mileage, condition, vehicle options *Depending on the specifics on your particular wheel, wheel spacers may need to be used. *All kits will not retain OEM Electronic Dampening Systems |
06-01-2022, 03:08 PM | #2 |
4923
Rep 115,999
07-06-2022, 02:53 PM | #3 |
4923
Rep 115,999
07-15-2022, 10:20 AM | #4 |
4923
Rep 115,999
08-04-2022, 12:02 PM | #5 |
4923
Rep 115,999
