05-17-2022, 01:55 AM | #1 |
Rep 20
F11 N57B30 lack of perfomance
Hello people! I have a problem from 2 months without success with resolving it. My car is F11 2011 530d xdrive with N57B30 (258HP).
The code i am receiving: 244C00 Charging Pressure Too Low The things i did: - Cleaned DPF with special machine (under pressure with chemicals, water and air). - Changed intake pipe with number 13718506702 - Cleaned MAF Sensor. Reseted adaptation of MAF sensor. - Changed all vacuum pipes The problem appears after kickdown or under heavy driving (after 2500RPM). For a moment, the car always wonders what should happen and a few seconds later it starts to go. Before resetting the values of the maf sensor after 2500 rpm did not turn on the turbine at all. I have logs maded with bimmerlink: https://datazap.me/u/ttsvetanov92/cl...k=607-644-1090 For now i am thinking of MAF sensor. But waiting for other opinions Thank you guys. |
