12-09-2008, 05:34 PM | #1 |
Moderator
670
Rep 4,737
E92 M3 Factory Alignment Specifications and Ride Height
Ride height:
From bottom of rim to fender. 18" Wheels Front: 610 mm Rear: 594 mm 19" Wheels Front: 623 mm Rear: 607 mm Competition package: -10 mm from above specs. |
12-10-2008, 02:24 AM | #4 |
Bored at work....
887
Rep 5,378
Very nice.
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
01-26-2009, 04:29 PM | #7 |
7
Rep 229
These are from the alignment I had my dealer do as part of delivery. I had to type them out because the printout doesn't scan well. Anyway, they are actually generic to the E9x 3 series. The only difference is that you can get more neg camber in the front of an M. Mine is set to -1.3(left) and -1.2(right) with the guide pins in place (incidentally the max I could get from my 335 was -0.5 and -0.7 with the pins out). It handles very well, but I am fairly certain it will scrub the outside tire edge when I autocross and I will end up pulling the pins, going for the max neg. camber (I have read you can get around -1.5) and setting the toe to 0 deg.
Front: Camber = -0.2 to -0.8 Caster = around 7.2 (this appears not to be adjustable) Toe = 0.03 to 0.20 Total toe = 0.07 to 0.40 Steer Ahead = -0.05 Rear: Camber = -1.6 to -2.1 Toe = 0.10 to 0.20 Total Toe = 0.20 to 0.40 Thrust Angle = -0.07 to 0.07 |
01-27-2009, 08:24 PM | #9 |
Veni Vidi Vici
89
Rep 2,750
Drives: '11 JB/BBe-6sp-e90
Garage List 2011 e90 M3-Sold [8.50]
2003 RS6 - Sold [0.00] 2009 e90 M3 - Gone [0.00] 2003 M3 SOLD [0.00] old 2002 [10.00] |
I only got -1.3 out of my front end.
So what's the consensus on who to buy from? Dinan TCKline ????? |
01-27-2009, 10:05 PM | #11 | |
128
Rep 1,144
The dinan units are not really camber plates as they only add -0.7 degree, which is not nearly enough. |
01-27-2009, 10:09 PM | #12 | |
Moderator
670
Rep 4,737
01-27-2009, 10:21 PM | #13 |
128
Rep 1,144
Then why bother? There is absolutely no reason for more than 1 degree on the street, and unless you go at least -2.5, no reason to bother for the track either.
01-27-2009, 10:35 PM | #14 |
Moderator
670
Rep 4,737
01-28-2009, 07:51 AM | #17 |
Moderator
670
Rep 4,737
If you are aligning at a dealer, then no need to print out. If at some other shop, then I would print it out.
03-01-2009, 02:08 AM | #20 | |
36
Rep 625
Also, if you go with the optimal -3+ for the track then you are likely to get pretty big oversteer, so then you need to adjust the rest of your suspension. I'd guess -1.5 - 2.0 would be neutral handling with significantly lessened shoulder wear.
Driving sideways: It's not faster, but damn it's more fun!
03-25-2009, 01:46 PM | #21 |
374
Rep 8,033
Great thread!
I am considering the Dinan springs, and wondering if I should have the camber plates installed at the same time since the suspension will be pulled apart anyway. The two sets of tires I've used are worn out bad on the outside. With the extra -.7, one would get pretty close to -2 degrees after the alignment, which would be a pretty good setup I think like jakeo is saying. A couple of questions I can't seem to find answers to: 1. How thick are the Dinan plates? (How much of a reduction in the drop) 2. How much do they weigh? If anyone has installed them, please let me know. I called Dinan, but can't get a hold of anyone there, and my Dinan dealer has not seen any yet, so he doesn't know either. Also, I've read mixed reports on pulling out the pin--if the pin even exists or not on the E9X M3. So, does it exist? And, is the -1.3 max negative camber people are reporting obtained with or without pulling out the pin?
03-27-2009, 02:36 PM | #22 | |
374
Rep 8,033
The camber plates are forged aluminum and result in a 1/8" reduction in the drop. They weigh less than a pound. If you max out the stock negative camber setting and add the plates, you'll end up with 2.0-2.1 degrees.
