04-16-2022, 01:13 PM | #1 |
1871
Rep 1,727
20" wheels potential issues?
Hello.
My new F33 440i comes with 19" 704M wheels but I would like to change them to aftermarket 20" items (probably 666m replicas). I have sorted the widths, tyre sizes, offsets, rolling radii etc, thanks to 'willtheyfit.com' but have a few questions I would appreciate advice on: My car has adaptive dampers and VSS, so not sure if there would be any issues with fault codes for these with bigger wheels? Also, will I need different TPMS sensors, or will these need 'coding' to the larger diameter? Any potential issues with the ABS sensors, etc? Thanks in advance |
04-16-2022, 01:20 PM | #2 |
1388
Rep 2,129
I have an F36 with VSS and adaptive. I upgraded to 20" and zero issues in 4 years
If you use your old tpms or new ones for BMW they should sync up fine.
Previous: 2010 F01 740d M Sport | 2015 F36 420d M Sport
Current: 2018 F36 440i M Sport (Stage 1 BM3, xHP stage 3) |
Pond1870.50 |
04-16-2022, 02:43 PM | #3 |
2472
Rep 4,653
Firstly 666m wheels are for M cars!
Secondly swapping OEM wheels for a set of cheap replicas probably made badly in China is crazy!
Steve Roberts UK
F82 M4 I'm running the 2024 London Marathon for the British Forces Foundation - https://www.justgiving.com/fundraising/sr5/ |
04-16-2022, 02:50 PM | #4 | |
1871
Rep 1,727
Most OEM wheels are made in Poland or Hungary, or anywhere that's cheap. They are not honed from a solid piece of English Oak. Many, many BMW, Merc, VW, you name it, wheels crack or warp. Don't see the difference TBH. I had an OEM Alpina 19" classic which was oblong! Cost to replace; £900! |
04-16-2022, 02:59 PM | #5 | ||
715
Rep 1,161
Chinese replicas are particularly soft and don't last well on UK roads, simply not the same construction from my knowledge. Armaan |
04-20-2022, 05:31 AM | #6 | |
The artist formerly known as AC Schnitzer UK
3610
Rep 4,518
The differences between OEM, reputable brands and cheap aftermarket wheels are certification and homologation. AC Schnitzer use TÜV technical services to issue certification, meaning the items meets specific quality standards for manufacture, and homologation, meaning the wheels have sufficient load rating and other characteristics that make it suitable for a specific vehicle. Sample wheels are tested to destruction. Most Chinese aftermarket wheels are not tested, and have no load rating at all. In the UK, it's legal to put untested wheels on your 2450kg Tesla. I can't recommend it though. All BMW, VW etc wheels, no matter where they are manufactured, will also have been tested or they couldn't be used on German roads. Last edited by Lorcan; 04-20-2022 at 05:40 AM.. |
Abzynthe1387.50 |
04-20-2022, 07:08 AM | #7 | |
2439
Rep 385
IIRC Ronal make many of the OEM wheels for the German manufacturers. |
04-20-2022, 11:30 AM | #9 |
2259
Rep 2,050
04-20-2022, 01:58 PM | #11 | |
1871
Rep 1,727
Every non-OEM wheel I've seen advertised is certificated for load to at least 690kg. That's more than enough for an 1800kg car. Last edited by Pond; 04-20-2022 at 02:24 PM.. |
04-21-2022, 05:42 AM | #14 |
342
Rep 1,826
Drives: Alpina G21 D3S
All I will say, with regard to tyre sizes, is go 245/30/20 and 265/30/20 if you can. A 225 front and 255 rear look under tyred.
