04-10-2022, 03:10 PM | #1 |
Rep 12
2014 328i N20 Wastegate Issues
So, I need some help. My wastegate opens and closes when I first start my car. But it won’t open under boost pressure, I replaced my cut-off valve, all of the engine fuses (because it’s impossible to find an in depth diagram.) It’s overboosting to about 40psi as well. I cannot figure out the cause of it. I don’t have any engine codes, and I don’t think it’s the wastegate actuator or the wastegate itself because it still opens and closes when the car is first started. I’m running FBO, GFB DV+ spacer, and a stage 2 agg tune from bm3. Can anyone help me diagnose and fix?
Edit: I have the electronic wastegate Last edited by Joshc99; 04-10-2022 at 03:34 PM.. |
04-11-2022, 05:22 AM | #2 |
¯\_(ツ)_/¯
947
Rep 1,762
I would tune back to stock and see if there is a change. Then replace the electronic wastegate, then remove the GFB valve.
I did read that there is a process to adjust the electronic wastegate when a new one is installed.
Tensioner/belt DIY | Side skirt extension DIY
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC |
04-18-2022, 11:07 AM | #3 | |
Rep 12
Yes it just tells you how to do it on ista, all you have to really do is adjust the nut |
