DIY - OEM Rear Deck Spoiler Lip (official instructions)
07-07-2005, 11:05 AM | #1 |
Administrator
40749
Rep 21,239
Click the following link for official instructions (in PDF) on installing the OEM Rear Deck Spoiler Lip.
Rear Deck Spoiler Lip Install Instructions P.S. The glue / adhesive you see in instructions is called Betalink-K1 (BMW part Number 82-69-9-408-866). It retails for 12.75 + tax ... and comes in a complete set with sand paper, glue, cleaner, applicator. Thanks to member "Tape" for this information. |
10-22-2005, 07:52 AM | #2 |
//Mdicted
347
Rep 9,988
Drives: a Cop Magnet
Garage List 2009 e92 M3 DCT CF ... [10.00]
2015 S-Works Roubaix [0.00] 2013 Trek Madone 5.9 [9.50] 2012 Scott - CR1-Pro [10.00] 2008 e92 M3 6MT (Up ... [10.00] 2002 e46 M3 Cabriol ... [7.00] 2006 e90-325i (DD) [7.00] 2002 e39 M5 (retired) [9.50] |
Official e90post's OEM Rear Spoiler DIY I like to share the DIY step-by-step photos that I took when I installed my spoiler the other day. It has all important visual information and also lessons I learned that I wrote in the photos comment block.I like to thank Jason from Tischer BMW MD who provided me the complementary Beta-link adhesive and a great deal. I almost walk off the dealership with just the spoiler package, thinking thats all i needed.
11-21-2005, 09:58 PM | #3 |
//Mdicted
347
Rep 9,988
part nos. of he OEM spoiler you need to order from the dealership:
1. e90 (only) Rear Deck Spoilers OEM P/N: primed paint required: p/n 51 71 0 396 344 Black Saphire p/n 51 71 0 398 220 Sparkling Graphite p/n 51 71 0 398 222 Titanium Silver p/n 51 71 0 398 224 Non-Metalic Black p/n 51 71 0 398 730 2. Glue/adhesive Betalink-K1 (BMW part Number 82-69-9-408-866)
04-02-2006, 05:36 PM | #4 |
//Mdicted
347
Rep 9,988
bump
for those folks who heard about edges working its way off, the key is 1. putting alot of betalink glue at left/right corner edges 2. taping it after for cure 3. homecdepot clamp them too 4. a 6 hrs cure time at weather temp of 60-90F NOTE: DIY Step-by-Step E90 Spoiler Install for Dummies http://www.bimmerfest.com/photos/sho...y.php?cat=3145 notes from jwarcd : - The spoiler I got did not fit the curve of the trunk exactly and had to be slightly bent when installing to match the trunk. Not a big deal, but makes is a little harder to install. - wear laytex gloves, the adhesive is pretty messy. - clean the trunk edge and the back of the spoiler really well with the BetaClean solvent that came with the 3M BetaLink adhesive. - lightly sand the back of the spoiler to give the adhesive something to grab onto. - Now it's time to install the spoiler. BTW, don't peel off the protective backing on the tape on the spoiler until after you have installed it. (Once it touches the car it's on for good!) How the heck do I do that you are thinking? :-) Before you install it peel off about 1" of the tape backing and bend it back so that it sticks out towards the front of the car. - Now, Put the 3M adhesive on the spoiler. Place the spoiler on the car and while you are pressing on the spoiler pull the tape backing towards the front of the car. - Use the blue painters masking tap to hold the spoiler in place while the 3M BetaLink adhesive dries. The blue tape is easier to remove, and doesn't leave much residue behind. I also used small spring claps to hold the ends of the spoiler tightly to the trunk since it wanted to spring up a little. - Clean up the the extra adhesive with the 3M BetaClean cleaner that came with the adhesive. - I missed a little adhesive that was under the masking tape and was able to remove it the next day with a little BetaClean and the platic tool that came with the adhesive. You just have to be patient and carefully scrape it. - BTW the adhesive doesn't come with the spoiler, it was about $15 at the dealer.
04-02-2006, 05:53 PM | #5 |
89
Rep 3,011
thank you. plan to add spoiler this may... my b-day present
"Teach the ignorant. Ignore the stupid."
04-02-2006, 07:10 PM | #6 |
517
Rep 18,858
My spoiler should be coming in on Tuesday this week. Ill have to arrange for it to be painted while I am away on vacation...
Ill do this DIY and many more when I return. After that, Im calling a mod hiatus for a long long time... |
04-02-2006, 10:11 PM | #7 | |
89
Rep 3,011
you're addicted to DIY.... admit it.
04-03-2006, 09:16 PM | #8 | |
517
Rep 18,858
OK... maybe strut bar, but thats it |
04-28-2006, 12:19 PM | #9 | |
517
Rep 18,858
Spoiler and splitters going on this weekend and next week respectively... Then no mods... Im going cold turkey... Lets see how long it lasts... |
09-08-2006, 03:08 PM | #11 |
72
Rep 402
Drives: 2023 G01 LCI X3 M40i
After completing the install I had a few issues with the removal of some of the betalink and the glue from the duct tape I used. I used the betalink solvent and used a cheap microfiber towel and ended up with a bunch of small swirl marks and scratches on the trunk and spoiler.
I was easily able to remove them using Zaino Z-PC, but would highly suggest two things to others who will be performing this install: 1) Use blue painters tape instead of duct tape as it will leave almost no glue residue. 2) When cleaning up any extra betalink that gets on the car, make sure you use the same high quality towels you'd use in the washing and waxing process. I should have known better in reference to issue 2, but since I didn't, I thought I'd share my experience so others won't make the same mistake.
My Garage | Phytonic Blue | Black Sensatec | Carbon Fiber Trim | Parking | Premium | Remote | Wireless | Harmon Kardon | 19" 887M Bi-color Midnight Grey |
09-14-2006, 10:10 PM | #12 |
//Mdicted
347
Rep 9,988
I find using a bag cotton balls soak with betalink link cleaning solvents (comes with betalink kit) works best cleaning up excess Betalink glue
09-15-2006, 03:25 PM | #13 | |
72
Rep 402
11-17-2006, 11:07 PM | #14 |
//Mdicted
347
Rep 9,988
Ive covered the area near the Spoiler with tape, when I temporarily intalled the spoiler and mark it.
Marking it and covering exposed area gives a very good indication of where it should be once you install it with the glue later. Covering the exposed area near the spoiler, will save you time cleaning up later by just pulling the tape with excess glue.
10-28-2007, 09:38 AM | #15 |
//Mdicted
347
Rep 9,988
Ive been asked time after time how my spoiler install has been holding up with betalink, some even asked photos.
Well, I figure I post it here for everyone to see thats its doing well after 2yrs and in all climate condition. The e90 is not garage and in a four season State. btw I have no experience removing installed spoiler, but I believe Longtran had experience removing them. PM him for more info. photos taken today Oct 27/07 hope it helps
10-30-2007, 08:45 AM | #16 |
Rep 129
Drives: 2017 430i Cabrio
Great DIY. I just installed my spoiler last night. I have a small amount of the adhesive to remove that squished out, but other than that it looks great.
2017 430i xDrive Cabriolet Retired: 2007 335xi Sapphire/Terra Premium Retired: 2006 325i, Premium |
02-16-2008, 11:24 AM | #18 |
Boris the Blade
17
Rep 317
Anybody?
I agree. I just received my CF spoiler, but I'm worried about this as well.
Allan
Montego Blue 335i Sedan w/Navi/Magnetic Black NISMO 350Z #831/76' Mini 1100 "SPECIAL" Export |
03-05-2008, 05:27 PM | #20 |
//Mdicted
347
Rep 9,988
the ones Ive used are not actually heavy clamps but alligator clips guys. CF are heavy duty, why would it crack?
03-09-2008, 08:50 PM | #21 | |
Rep 22
1. Will the two rows of double sided tape be enough 2. If I do have to use glue where do I put it since there is only a small area between the two rows of tape to put the glue. |
04-25-2008, 12:57 PM | #22 | |
//Mdicted
347
Rep 9,988
2, see illustration 17 from the photo DIY, DO NOT APPLY GLUE AT EDGES also: http://www.bimmerfest.com/photos/sli...=6186&cat=3145
