BMW M3 Forum (E90 E92)
BPM
      12-05-2008, 11:04 AM   #1
AZE92M3
11
Drives: Alpine White E92 M3
Kidney Grill Removal?
Can someone please explain how to remove the front kidney grills? Do I need to remove any bolts or is there a trick to just popping them off? I searched but couldn't find anything. Watched a great DIY on how to paint them....but I can't even get them off. Thanks.
      12-05-2008, 11:26 AM   #2
mPlasticDesign
mPlasticDesign's Avatar
684
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
You shouldn't try to just 'pop' them off. You are almost garanteed to break the clips if you do this. You have to remove the 4 bolts on the fron bumper and reach in behind to press on the clips to remove the kidney grills. Good luck!
      12-05-2008, 11:52 AM   #3
///M3Power
8
Drives: M3
http://www.e90post.com/forums/showthread.php?t=47059
      12-05-2008, 11:54 AM   #4
endofanera7
endofanera7's Avatar
514
Drives: 08 JB E92 M3
is your friend!
Anyway, Good luck!
      12-05-2008, 01:02 PM   #5
AZE92M3
11
Thank you for the help. I tried searching but nothing useful came up. Thanks!
      12-05-2008, 01:48 PM   #6
///M3Power
8
Drives: M3
Google search works great, just type in the words:
E92 M3 front grill removal
      12-05-2008, 04:03 PM   #7
gemini330zhp
gemini330zhp's Avatar
Philippines
34
Drives: 2008 M3 E90
Remember the clip that is near the headlight is a pain in the you know what. I started with the clips on the bottom then the clip near the headlight with a little screwdriver and everything else popped out nicely. The other grill was easy after that.
2008 Jet Black E90 M3 6SPD no sunroof and 18s to my specs
      12-05-2008, 10:30 PM   #8
ILLCOMM
ILLCOMM's Avatar
29
Drives: GT2
I cannot describe the PIA that getting the clip closest to the headlight to release. I mean, it was hell.
      10-29-2010, 03:20 PM   #9
ThunderMoose
746
Drives: PY E46 M3 and SG E46 M3
My fingers don't work now after working out the two clips closest to the headlights. I am typing with a pencil in my mouth.
      01-06-2011, 09:09 PM   #10
bunny
bunny's Avatar
Drives: e92 m3
This DIY was super helpful! I just installed my new gloss black kidney grilles in less than 10 minutes. I pushed down on the clips and pushed towards the grille (instead of pulled) and it popped out with ease. I agree that the clip closest to the headlights was the hardest to pop out, but I think having small fingers/hands helps
      03-19-2011, 03:10 PM   #11
hbcpa
hbcpa's Avatar
Drives: 2011.5 MR E90 M3
Thanks for the link Bunny. You are Superwoman to do the install in 10 minutes.
I suffer from slight nerve damage in my hands as a result do not have 100% strength in the fingers. I used 2 flathead screw drivers one 3 1/2 inches the other 7 inches in length. Using these two I could wedge the 3 1/2" near the light (definitely the hardest clip) while using the 7" for the other clips.
      08-30-2011, 10:53 PM   #12
M3-Mike
M3-Mike's Avatar
53
Drives: 2020 M2 Competition
Thanks for the installation tips... pretty easy to swap grilles once you know how!
Here is my M3 with the new "Edition" black chrome grilles... before and after
      08-30-2011, 11:37 PM   #13
schnell325
Bored at work....
schnell325's Avatar
890
Drives: 2016 F82 M4 GTS//2022 M235iGC
Yup, did my wife's E90 in less than 5 minutes!
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD!
Anti Matter :2016 F82 M4 GTS
What next?!? A 2022 M235i GC- I must be getting old
      10-20-2012, 10:11 AM   #14
webgroggy
Drives: 2006 M5
Quick and easy. MANY thanks for the info!
      12-07-2012, 01:12 PM   #15
DopeM3
M Power
DopeM3's Avatar
Drives: M3
Quick and easy! Remove the 4 screws, pull the bumper a bit forward (not to hard), and press firmly on all the tabs holding the grill. Should be in and out in less than 15 minutes.
      07-05-2013, 11:55 PM   #16
jevanh
10
Drives: BMW 323i E90
Hi there does anyone have the problem of the torx screws on either side of the eyebrows to on the bonnet just spinning and not coming out? i can only unscrew the middle ones out of the 3..
Attachment 208731
m3post
