03-27-2022, 10:57 AM | #1 |
579
Rep 455
G8x Coding - List of Solutions Only
It seems like all of the coding threads get sidetracked with a bunch of questions other discussions. As such, we don’t have a good list of solutions.
So for this thread, Please refrain from asking questions or having discussions. Only add coding solutions or instructions that you know work for G8x cars. Please identify if it was done via Bimmercode or E-Sys. If you used E-sys please list what version, launcher and psdzdata that you used (and where to get it, if it’s still available), as well as what series you used when connecting. Please only include Bimmercode items that required using expert mode as the other options are easy. Bimmercode I used an iPhone and the OBDLink CX Change Color of Car in iDrive and Instrument Panel - Head Unit (HU_HGU) > Expert Mode > 3000 HMI_SPEECH > VEHICLE_COLOR > Your desired color Retrofit OEM Wireless Charge Pad with Reminder - Body Domain Controller (BDC_BODY3) > Expert Mode > WcaWirelessChargingAblage > WCA_ENABLE > aktiv - Head Unit (HU_HGU) > Expert Mode > 3000 HMI_SPEECH > WCA > aktiv E-Sys I have not been able to get a version of the launcher and psdzdata that works for FDL coding with either my 2022 M3 or 2022 M440i.
Current: 2022 ///M3 San Marino Blue, Comp, xDrive, Fjord Blue/Black --plus-- 2022 ///M440i Gran Coupe, Aventurin Red, Cognac Vernasca
Past '20 X4 ///M Competition Toronto Red -- '16 ///M3 Tanzanite Blue, ZCP -- '15 ///M3 Mineral Grey Last edited by Barathon; 03-28-2022 at 08:17 PM.. |
03-28-2022, 08:49 AM | #2 |
325
Rep 238
I've been trying to add everything I've found at the first post of the E-sys thread. Btw, for a copy of E-sys, message shawnsheridan, he'll point you in the right direction.
2022 G80 XDrive - Current Daily Driver 2002 E53 - Winter Crasher 2015 F32 - Sold 2009 E90 - Sold |
dimab0233.50 |
03-28-2022, 08:32 PM | #3 |
579
Rep 455
E-SYS
Anti Dazzle I used E-SYS v3.30 and the Launcher Pro found here: https://bmwtune.com (The site appears to be down now but was up yesterday) and v.4.34.12_PSdZData_Lite that I got from shawnsheridan *Using this setup I was only able to do the VO coding, FDL coding doesn't work correctly* I followed the instructions on this video. When I did the coding with E-SYS it wiped out the coding that I did with Bimmercode, but that was easier to add back in. All of the Anti Dazzle features appear to be working correctly.
Past '20 X4 ///M Competition Toronto Red -- '16 ///M3 Tanzanite Blue, ZCP -- '15 ///M3 Mineral Grey Last edited by Barathon; 03-29-2022 at 06:39 AM.. |
Rosetta Stoned99.00 |
04-05-2022, 12:12 PM | #4 | |
234
Rep 269
Or, if you prefer, can move this convo to private message and I am happy to delete my post here.... |
04-22-2022, 01:33 PM | #5 |
579
Rep 455
I decided to purchase BimmerUtility and try that out. Before doing anything with BimmerUtility I restored everything back to the original settings with the tool that I changed them with (E-SYS for VO and Bimmercode)
Here are the things that I have confirmed as working using BimmerUtility. BimmerUtility Wireless Charging Pad Retrofit BDC_BODY3 > WCA_ENABLE > nicht_aktiv to aktiv HU_MGU > WCA > nicht_aktiv to aktiv Turn off Legal Disclaimers HU_MGU > LEGAL_DISCLAIMER_TIME > id_mit_timeout to kein_ld HU_MGU > MACRO_CAM_LEGALDISCLAIMER > id_mit_timeout to kein_ld HU_MGU > MACRO_NIVICAM_LDISCLAIMER > id_mit_timeout to kein_ld Show entire SMS HU_MGU > PIM_Driving_Text > up_to_three_lines to Whole_text Change Car Color in iDrive and Instrument Panel HU_MGU > VEHICLE_COLOR > your default to your preference Bowes & Wilkins Codec HU_MGU > Audio_System > alev3_ram to alev4_ram Anti Dazzle ** I am by no means a coding expert, I compiled this list by doing a ton of research and talking to others on the forum. Anti Dazzle is working fully and properly to my knowledge, that said, it is possible that there could be other things that increase functionality even more. Perhaps Almaretto and shawnsheridan could give their inputs. I did have to do the VO coding, contrary to some reports that it wasn't required. BDC_BODY3 > LUT_FLC_FORWARDLIGHTING_Y > no_AFS to AFS BDC_BODY3 > C_BLC_PRE_ENA > Disable to Enable BDC_BODY3 > C_AFS_ENA > Disable to Enable BDC_BODY3 > C_AFS_ECO_LEVEL_3_ENA > Disable to Enable BDC_BODY3 > LUT_AFS_DRV_VERT > G22_Laser_US to G011/G22_Laser_ECE BDC_BODY3 > C_CLC_CURV_V3 > US to ECE BDC_BODY3 > C_HBA_GFHBA_ENA_V_HI > 55km/h to standard FLM2 > Lmm1_Data > Wert_2 to Wert_1 FLM2 > Lmm2_Data > Wert_2 to Wert_1 FLM2 > Staging2_Data > Wert_2 to Wert_1 KAFAS4 > C_FLA_US_SENSITIVITY_MODE > US to Normal [00] KAFAS4 > C_FLA_BS_ENTER_THRESH > US to Rest of world [03] KAFAS4 > C_FLA_BS_EXIT_THRESH > US to Rest of world [02]
Past '20 X4 ///M Competition Toronto Red -- '16 ///M3 Tanzanite Blue, ZCP -- '15 ///M3 Mineral Grey Last edited by Barathon; 05-10-2022 at 06:29 AM.. |
evilboi7777.50 |
04-25-2022, 01:55 PM | #7 |
885
Rep 897
Funny you should ask this I was just looking on the G20 board to see if anyone has done this. Looks like its possible I am just not sure of the right way to set it up.
Tall Tom Cruise1009.00 |
05-13-2022, 12:37 PM | #10 | |
18856
Rep 14,140
Drives: G82 M4C X-Drive
Copy/paste from my original thread here.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
07-27-2022, 06:06 PM | #11 | |
579
Rep 455
Past '20 X4 ///M Competition Toronto Red -- '16 ///M3 Tanzanite Blue, ZCP -- '15 ///M3 Mineral Grey |
07-27-2022, 06:14 PM | #12 |
18856
Rep 14,140
Unfortunately my car is in the shop, and it might be awhile. Do you have a screen shot of what you see?
07-27-2022, 11:02 PM | #13 |
516
Rep 352
Tagging for later
ig: retroviol3t
08-01-2022, 11:12 AM | #14 | ||
755
Rep 298
G80 ///M3 XDRIVE
08-01-2022, 09:25 PM | #16 | |
579
Rep 455
