ISTA+ Transfer Box Reset
03-22-2022, 05:31 PM | #1 |
254
Rep 502
Does my version of ISTA+ allow for resetting transfer case adaptations when changing the fluid?
There are many posts about this on the forum, but most point to using DIS, some versions of INPA (not sure if my version supports), or certain versions of ISTA-D which have Transfer Box Oil Change option. Here's my Transfer box service menu in ISTA+. Can the calibration service be used safely to reset adaptations when changing fluid? Photo link not working: https://ibb.co/4Z1Zk06 |
03-29-2022, 12:19 PM | #4 |
254
Rep 502
Can you navigate to Vehicle Management -> Service Functions -> Power Train -> Transfer Box Transmission Control Unit and then see the option for Transfer Box (VTG): Calibration?
If it's the same, we just need a confirmation from someone that this is the correct selection when changing fluid and not some other Transfer case or motor actuator replacement. Different versions of ISTA seem to have an explicit option for Transfer Box Oil Change. |
