03-09-2022, 03:31 PM | #1 |
62
Rep 152
Replacing rear axle shaft
I blew up my rear driver's side axle and am looking to replace it. I've not replaced an axle before and am looking for info on how to go about doing it. ISTA says to drop the diff but I was thinking about dropping down the hub assembly.
Does anyone have any guidance on how to go about replacing the axle shaft? I was surprised that there is no youtube video or anything on it. They all show the replacement on prior models which have a different setup. |
03-10-2022, 06:52 AM | #2 | |
437
Rep 787
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
03-10-2022, 03:47 PM | #3 |
437
Rep 787
Pussiwillow522.00 |
03-10-2022, 06:13 PM | #4 | |
522
Rep 1,148
Jvac436.50 terryd5150507.00 |
03-10-2022, 06:33 PM | #5 | ||
437
Rep 787
Pussiwillow522.00 terryd5150507.00 |
03-10-2022, 09:59 PM | #6 | |||
522
Rep 1,148
terryd5150507.00 |
03-11-2022, 10:41 AM | #7 | |
62
Rep 152
Popping the axle out of the diff was really easy. 2' crowbar and a piece of a 2x4 and she popped out easy. The bar has to have a thin end like those used for pulling nails in order to fit in between the axle and diff. Unfortunately, the other end seems to be seized in the hub I don't have a press and am mushrooming both ends of my punch trying to get it out. Used ones are cheap enough so I'm going that route. |
Jvac436.50 |
03-12-2022, 07:22 AM | #8 | |
Head Fry Cook at McBurgertown
507
Rep 1,005
You mean the money I just spent on an LSD, clutch, and FMIC? Lol. |
Jvac436.50 |
03-12-2022, 11:53 AM | #9 | ||
437
Rep 787
terryd5150507.00 |
07-15-2023, 05:00 PM | #10 | |
32
Rep 79
07-16-2023, 02:58 PM | #11 |
@lbb_kev
494
Rep 515
Best to buy it used on ebay that came off of a decently low mileage car. I got one for $400
Speedtech Stage 3 (8474) | Remus Exhaust | Wagner EVO 3 | XClutch | DS2 + Lift Kit | Nostrum S2 Injectors | TI E5LM | Torqbyte EKP | Intrax 1K2 | SPL | Drexler GT Race Light LSD by limitedslip.de | Schirmer Diff Lift Kit
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage |
07-18-2023, 10:42 AM | #12 |
32
Rep 79
07-19-2023, 09:46 AM | #13 |
32
Rep 79
Axle replacement went very easily.
Unbolted all but (2) of the rear control arms and end link. I used (2) of the pry bars seen in the picture below and it came out, with relatively minimal effort. Switched over the dust cover as my new axle did not come with one and popped the new axle in. It requires a little force to push in, but with one hand on either side of the differential side boot and a quick jolt, it went in fairly easily. The hardest part was getting the new axle spline through the hub... I have brand new hubs and a new axle. For anyone trying this, I highly recommend the CTA 5056 tool. I could not get the axle into the hub without it. |
01-28-2024, 12:11 PM | #14 | |
89
Rep 69
Mods: Stoptech Sport Brakes, Injen Intake, BMS Catch Can, AFE Downpipe & 328i Sport Exhaust, Evolution Raceworks Chargepipes, VRSF intercooler, AFE tBody Spacer, MHI Big Turbo, BM3 Stage 2 93 Octane tune, Bilstein B8 Sport+ dampers, Dinan Perf Spring Set & Camber Plates
01-30-2024, 07:25 AM | #15 | |
32
Rep 79
getting the axle to go in the new hub was an absolute nightmare. Which I later found out was because every time I put a new bearing in I was binding/distorting it. If the bearing doesn't go in perfectly straight with a legit shop press you run the risk of this happening. Having said that, this tool helped pull the axle through the bearing: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
