02-28-2022, 09:15 AM | #1 |
Rep 6
Can anyone give me a driving lesson? And window help
So my first BMW is also my first automatic and first rwd. My problem is stopping, coming to a stop you can still really feel the kinnect energy jolting you forwards as you stop. I tried easing off the brake as I come to a stop but I almost rear ended someone. Any tips on this..?
My problem with the window is it isn't automatic going back up and stops half way. I've tried holding down the button once it's down for 10-30 seconds and holding it up when it's back up for 10-30 seconds but it still didnt fix it. On the service history it's had a new window motor, does it need to be coded like everything else in a BMW? Thank you! |
02-28-2022, 10:21 AM | #2 | ||
1045
Rep 1,343
02-28-2022, 03:38 PM | #3 | |
Rep 6
02-28-2022, 06:30 PM | #4 |
1045
Rep 1,343
Soft? To have emergency braking you should do it rather hard: press the brake pedal quickly, completely and hold it firmly until the car stops. If that doesn't seem to work you should have your braking system inspected! There's no error message and/or indicator light, I presume, so it should be a matter of servicing/maintenance: what about the braking fluid which should be changed every two years?
03-02-2022, 03:44 PM | #5 | |
Rep 6
Also my engine light came on for code p115c MAF not receiving enough air, I turned it off came back 15 mins later and the engine light disappeared. Any ideas?🤔 |
03-02-2022, 06:31 PM | #6 | ||
1045
Rep 1,343
03-16-2022, 10:16 AM | #7 | |||||||
12
Rep 7
03-16-2022, 10:18 AM | #8 | ||
12
Rep 7
Cool where are you |
DaveF82k9.00 |
