02-21-2022, 06:59 PM | #1 |
75
Rep 143
Rear diff clicking
Was wondering if anyone with a 2020 or 2022 X3M comp hear a clicking noise from
The rear diff area at low speeds less than 10-5mph? I hear it while going this slow and letting off the throttle and lightly getting back on it to accelerate. Thanks! |
02-21-2022, 08:59 PM | #2 |
984
Rep 1,708
Drives: 22 X3MC MBB - C-17 Globemaster
I recently started hearing a clicking when I start the car, from the rear, I swear it sounds like engine noise making its way through to the exhaust.
I know people have said their exhaust valves have clicked, but this seems different.... could be what youre hearing too, loud engine lifters |
ghstm274.50 |
02-22-2022, 07:31 AM | #3 |
1231
Rep 2,602
I hear the same thing, a click when driving slow off the throttle or braking. It sounds worse than an old U joint going bad.
2020 X3M non-comp, Alpine White over black : Exec Pkg, ventilated M Sport seats, 20"s
2020 M2 Comp, Sunset Orange/Blk: Orange stitching, DCT, exec pkg, bicolor rims Gone '18 M550i, '16 X4 M40i, '15 M5, '13 X3 35i, '12 335is, '11 X5 50i, '09 Z4 35i, '08 550i, 06 X3, 06 650i, '02 M5, '99 540i |
ghstm274.50 |
02-22-2022, 08:46 AM | #4 |
1318
Rep 1,067
https://x3.xbimmers.com/forums/showthread.php?t=1837347
See this thead, and there are others. It's a known issue on the M2, M5, and X3 M and probably every M. |
ghstm274.50 |
02-22-2022, 01:20 PM | #5 | |
75
Rep 143
02-23-2022, 08:19 AM | #6 |
1231
Rep 2,602
Good to know there's an easy fix.
02-23-2022, 09:38 AM | #7 |
75
Rep 143
So, I guess per BMW, rear diff needs to be replaced because of the clicking. Sounds like this SB wasn't even looked at or considered as potentially fixing the issue?
02-24-2022, 10:37 AM | #9 | |
75
Rep 143
05-12-2023, 12:38 PM | #10 |
Rep 23
Drives: x3m comp
the fact that BMW hasn’t made this a recall yet is quite annoying… i’ve had this problem since about 5k miles… Have taken the car to dealership twice, both separate dealers and they “can’t recreate the noise/problem”
05-13-2023, 09:26 AM | #11 |
1318
Rep 1,067
i can't believe what I'm reading. Or maybe I can. Depressing.
In my case, the issue was easily reproducible - I could play a tune just by tapping the throttle on and off. The dealer said they submitted the issue to BMW corporate to create a service advisory. I had printed out the service advisory for the same issue in the F90 M5 and handed it to them - they said that helped. In my case, the click was really annoying and took away from the enjoyment of the delicious exhaust. |
05-13-2023, 11:52 AM | #12 | |
75
Rep 143
It’s easier to show then to explain to them sometimes.. |
mtl8852.00 |
05-13-2023, 12:18 PM | #13 |
333
Rep 687
https://g05.bimmerpost.com/forums/at...8&d=1654474068
Found this Service Bulletin for X5M/X6M, may apply here as well, check it out.
2011 E90 M3 ZCP Space Gray - gone but never forgotten.
2002 E46 M3 Carbon Black - my “M” first love. |
Commanderwiggin2051.50 |
05-14-2023, 02:58 PM | #14 | |
131
Rep 110
ghstm274.50 |
05-15-2023, 10:26 AM | #15 | |
Rep 23
Drives: x3m comp
i have service due in 1000 miles.. going to make it my absolute mission to work w my service advisor and get this problem resolved. it’s so frustrating |
05-23-2023, 02:17 PM | #16 |
Rep 15
I had a thread going for my car. I ended up having to go to a second dealership to get any resolution though. First dealer said it was normal for M cars and I disagreed.
Short version: Second dealer had foreman drive with me, was able to reproduce the sound he said they’d look at it and I mentioned the service bulletin everyone references on the m2,3,5. They opened a case with BMW, an engineer came in to inspect the car bc they thought it might be the transmission and they ordered a new diff and replaced under warranty. So far the sound has been resolved, but I’ve only had the time to drive the car like 10 collective miles since then so not enough to definitely say it’s solved. But in the stop and go traffic scenario no more clunking/clicking. https://x3.xbimmers.com/forums/showthread.php?t=2007042 |
ghstm274.50 |
08-28-2023, 09:45 AM | #18 |
405
Rep 302
Small update 22k miles and rear differential replacement ( clicking like everyone have)and front mounting struds loose( clicking on steering wheel when parked)so replace too ;/ that what I know x3mc got this issue, my service advisor told me my is second what he got with this issue
09-10-2023, 08:45 AM | #19 | |
Rep 5
09-13-2023, 07:58 AM | #20 |
22
Rep 189
I had the loctite work done, it’s less frequent but click still there off the line. What I can’t understand is whether there is long term risk here or is BMW doing the picture to just try and reduce the noise?
09-20-2023, 05:01 PM | #22 |
350
Rep 328
Drives: BMW
Hello friends,
I've probably posted this exact message at least a dozen times, but I love the community to keep on sharing my advice. Ignore this, it goes away and doesnt' cause any problems... I had it on my 2020 x4m, brand new off the showroom floor, within the first 2000km of owning the car.. not sure exactly how early it started after having it delivered.. but it was within the first weeks.. at one point i got all worked up and stressed about it, but slowly forgot and now it has gone away on its own. Just keep in mind, this is coming from the rear DIFF, which is a DIRECT part from the mighty BMW M5. It won't break on you, just drive it harder and ignore it.. or you can rip your drivetrain apart and create god knows what new problems. Up to you, you've been warned! |
