02-13-2022, 02:34 PM | #1 |
751
Rep 402
Q for those who are lowered & have laser lights
Afternoon all- happy super bowl Sunday.
Having an issue with pissing off oncoming traffic. Since lowering my vehicle 5-6k miles ago on ASTs, each evening/night when I’m driving home from work I have multiple folks high beam me and give me the 1 finger salute thinking I’m rolling with my hi’s on. I worry the spring obviously changed the angle of the light projected, and results in me filling the cabin of the oncoming vehicle with too much light. What doesn’t make sense to me, is that the spring lowered the front end at a more drastic angle to where I’m more so nose down then I was from the factory? Anyone else having a similar problem?! I don’t recall having a near the same amount of issue prior to the drop. I hate to light people up, after their aggression tho it’s kinda funny. They go from thinking I’m hi beaming them to them being on center stage at a nickelback concert…. I had an evo Where you could actually adjust the height of the projection of the headlight. Wonder if these can be adjusted? Any tricks or tips? Anyone else? Last edited by mattburks; 02-13-2022 at 02:39 PM.. |
02-13-2022, 02:49 PM | #3 |
751
Rep 402
02-13-2022, 03:59 PM | #4 |
4949
Rep 3,820
Front suspension has a level sensor that adjusts the headlights according to ride height. My guess is the laser lights are just brighter than people are used to and by coincidence, people have been flashing you after lowering.
mattburks750.50 |
02-13-2022, 03:59 PM | #5 |
never could compete with Lloyd Braun
5276
Rep 5,379
I'm lowered on ASTs too since October and never once have i been flashed and I drive my car daily. I do also have full anti-dazzle coded so maybe that's helping.
Limegrntaln13560.50 |
02-13-2022, 04:53 PM | #7 |
94
Rep 98
I get flashed alot on stock height and love hitting then back. I wish the lasers in Canada functioned like they do in Europe.
15 F82 M4 (sold)
16 F80 M3 (sold) 20 F90 35 Jahre 22 G80 M3 XDrive |
Limegrntaln13560.50 mattburks750.50 |
02-13-2022, 06:16 PM | #10 | |
475
Rep 608
G80 Comp, Hcp custom e50, 9.69@141
F90 Comp, Hcp custom e40 meth, 9.76@143, 174ml/h 1/2ml 60-130 5.53 F10 M5, HCP Tune ,BM3, 10:8@137, 166.05 1/2ml. Ig @mcc420 |
02-13-2022, 06:24 PM | #11 |
13561
Rep 7,002
Drives: 2022 DG/BLk xDrive M4C Wk 34
I would never manually adjust my headlights. There is just too much that can go wrong. You'll end up with your headlights pointing in all different directions. It's like trying to eyeball your wheel alignment.
2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou |
2011ninja3412.50 QuarterMileJoe9.00 |
02-13-2022, 08:40 PM | #13 |
149
Rep 65
My daily driver is a GMC Sierra 1500 AT4. It really has quite good LED lights.
Sits basically normal height for a 4WD truck. Which naturally Means it’s taller than passenger cars. At night if I’m across from someone it shines directly into their eye line, unfortunately . Nothing I can do about it. But 4/10 people just assume I have high beams on so they flash their high beams at me and then proceed to flash them at a rapid pace by pulling their stalk back 50 times, in anger… My response is to do the same and actually show them the high beam. Only then has it registered to them that maybe it’s just a pickup truck that’s higher than their car . For their lack of brain use , I take great pleasure in blinding them. |
02-14-2022, 09:31 AM | #15 |
1745
Rep 1,700
BTW my car is lowered on KW HAS. My lights ended up way too low after the work was done. One full turn counter clockwise fixed the problem. The lights are designed to have the height adjusted, there is no magic to it. Have done it on all of my BMW's for years since I think they come way too low from the factory usually.
mattburks750.50 |
02-14-2022, 09:51 AM | #16 |
3290
Rep 6,732
Low is understandable after lowering but usually if they are high after lowering, the sensor being incorrectly set or broken can be a culprit. Not sure why they default to high vs low.
Known issue across the several M’s I’ve owned and for some reason or another, I or a shop has broken or installed incorrectly at some point lol |
siegester344.50 |
02-14-2022, 10:45 AM | #17 |
751
Rep 402
All of this has been super helpful!
Where is this sensor that might be broken be located? My car is currently at dealer for service, so I will look into this as soon as I retrieve. I'm wondering if either: A. My sensor is broken B. The shop that installed my springs and spacers adjusted as salespunk describes and made an over correction. I sincerely feel like with my experience vs with what you all are sharing points to something not being right with mine. I'm not an overly sensitive person lol, I assure you I can drag a county road heading home for 1-2 miles and I can have multiple different parties independently flash me as they pass. |
02-14-2022, 10:49 AM | #18 |
751
Rep 402
I also back up me having an issue due to the fact that I can see into their vehicle in black night, and clearly see them letting me know I'm #1!
As funny as it is, I do feel bad. I think I'm angled too high and am going to try and adjust. Thanks Salespunk Any tips or tricks, or really that easy? |
02-14-2022, 11:01 AM | #19 |
19584
Rep 10,193
I dont drive at night.
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
chicagofan0019254.00 |
02-14-2022, 11:05 AM | #20 |
206
Rep 349
02-14-2022, 11:12 AM | #21 |
///M ♥ Recycled Dinosaurs
3212
Rep 1,781
Drives: BMW M4, BMW X5 45e
It's in the process of being legalized. Practically, since the obnoxious people who drive around with their high beams on do not get ticketed 99.9% of the time, nothing's going to happen for this either. Totally depends on if you're a by-the-book person or if you look at what practically improves safety for everyone.
2022 BMW ///M4 Comp M xDrive (Enzian, Kyalami - insta | youtube | bp featured: Delivery + 963M + 2x Enzian!) | 2021 BMW X5 45e (Carbon Black Metallic, Ivory White)
BMW CCA LIFETIME MEMBER | Past cars: 2016 BMW 435i Gran Coupe (Carbon Black Metallic, Oyster White - Euro-delivery) |
JTO245276.00 |
02-14-2022, 11:58 AM | #22 |
5276
Rep 5,379
It is but as the other poster addressed, they're finally legalizing it... with that said I paid a forum member on here to code the feature in to be 100% functional. One of the best mods to do on the car, personally. Driving at night is so much better.
2022 G80 M3 6MT | Skyscraper Gray | Kyalami Orange
2018 F87 M2 6MT | Alpine White (sold) 2016 981 Cayman 6MT | Jet Black (sold) 2015 F80 M3 DCT | Tanzanite Blue | Gold Brown (sold) 2013 E92 M3 6MT | Mineral White | Fox Red/Black (sold) |
