02-13-2022, 04:25 AM | #1 |
Rep 9
Looking to get 19x9.5 +35 rims for my 2013 328i, would this rim size fit ? New to the car scene and im getting mixed information. What tire size would you all recommend for a square setup?
I am also considering 18x8.5 +30 rims, any recommendations and input is highly appreciated! I am running a stock suspension, and also trying to stay away from spacers. |
02-13-2022, 08:05 AM | #2 |
8245
Rep 16,088
Ask/search here: https://f30.bimmerpost.com/forums/fo...play.php?f=423
02-22-2022, 04:03 PM | #3 |
Modder of everything I own
147
Rep 491
On my 2013 335xi I have 19x9.5 ET20 with 255/35/19 on mine, with the offset at 20 my tires poke out from the fenders about 3/4 inch, just the way I like it!
There is about 3/4" of clearance between the front struts and the tire so with a stock offset of 34 (about 0.55" closer to the strut) I would still have a bit of poke out with this wheel/tire combination. I'm running a square set up with coil overs set stiff so my tires don't rub. There is no clearance issue anywhere else.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
02-22-2022, 04:15 PM | #4 |
147
Rep 491
here's a pic, can't really see the tire poke out from the side.
03-11-2022, 10:29 PM | #5 | |
Rep 1
