E90 335d SM200 alignment review help
02-10-2022, 04:01 PM | #1 |
369
Rep 554
Sorry for starting new thread. I would appreciate community feedback on alignment
E90 335d Sport SM200 kit: Bilstein B8 + Eibachs, 1" drop front: 225/40/18, rear 255/35/18 with PSAS4 Commute: 190mi highway, 70mi of which is nice mountain serpentine. Before alignment: - steering response was great - perfect straight line - heavy front tire wear on outer shoulders Target preference: 1) reduced tire wear 2) decent steering response at 65mph on mountain section I gave the shop attached specs, but final report seems to be not what was expected. Specifically, total toe seems to be to high. Help/feedback needed Should the final numbers be close to - front toe 0.07', 0.14' total. (report says total is 0.26' too much?) - rear toe 0.09', 0.18' total. (report says total is 0.38' - too much? ) Am I reading numbers right? FCobra94 Last edited by POBEP; 02-10-2022 at 07:36 PM.. |
02-12-2022, 12:55 AM | #2 |
302
Rep 543
euro use degree/minutes vs the decimal degree, so you need to do the conversion yourself since it seems they are not euro familiar. looks ok, my personal preference would be a little less toe in f & r and a little more neg front camber.
if you got outer shoulder/cornering wear only on your dd, you should look at tire inflation, tire quality, and tire widths Last edited by 335i54n; 02-12-2022 at 03:33 AM.. |
POBEP368.50 |
03-01-2022, 02:38 PM | #3 | ||
369
Rep 554
I drove the car for ~500 miles and it (steering) does not feel like BMW anymore. I plan to visit shop for (re)alignment tomorrow. Quote:
Front tire size were factory spec (as so rears now as well). It appears that pressure was the key. I think I ran old fronts tires low (32psi) for some time. Not sure how managed to misread values on the door. |
03-02-2022, 10:24 AM | #4 |
302
Rep 543
if you like how the car drove before, then go back to those total toe setting. i like .18 in the front and .3 degree like before in the rear, which should help the turn in feel. if you can take out some rear camber that will help with wear-likely already maxed. imo 225 in front is just too small of a front tire, a lot of psi will help but best upgrade is wider fronts. you can go even less/zero toe in the front for better turn in but i found it unpleasant highway cruising, too twitchy
POBEP368.50 |
03-02-2022, 12:40 PM | #5 | ||
369
Rep 554
335i54n thanks for the h-m-s vs decimal degree education.
I was under impression that I am looking at different units, but could not put 1&1 together until your previous post Quote:
I just got new set of staggered PSAS4-s - so will have to run with it for now Last edited by POBEP; 03-02-2022 at 05:26 PM.. |
03-11-2022, 10:58 AM | #9 | |
369
Rep 554
I hope they did (though the report shows otherwise) I adjusted tire pressure few miles before going to the shop. The alignment rack had all 4 tires connected to inflator. The E90 steering now feels great (335i54n thanks for review/feedback) On a side note, finding a good shop is a challenge in Bay Area. Labor pricing is astronomic & mechanics experience is concerning. On top, I dislike spending time driving to the shop, waiting several hours for rack availability only to come back again and point to deficiencies. Time & quality is what made me shift from hired labor to DIY. I still use hired labor for alignment and very limited maintenance items. Transmission service is one of them - too much mess. I will probably have to pass on N52 OPG DIY too. |
03-14-2022, 11:23 PM | #10 | |
Boost>N/A
29
Rep 73
Next time just go to TrackSpec in Fremont. Jon and his crew are very knowledgeable. |
POBEP368.50 |
05-10-2022, 02:42 PM | #11 | |
369
Rep 554
Haideezy Trackspec Autosports team is really good, indeed. I took my E70 35d for alignment today. Price was a bit on a higher side. Timing, quality and execution speed payed off extra premium. Definitely worse 500mi round trip travel to the shop. Thanks for advise
