Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > BMW e91 318i 2006 smoking
      01-30-2022, 01:36 PM   #1
Epokepok e91
Drives: Bmw e91 318i 2006
I have a Bmw e91 318i 2006 that is smoking alot when idle. It smells burnt and can sometimes look blue.
Things that I have confirmed:
CCV system is changed and good
Valve stem seals good
Head gasket is good
Valve cover new with new gasket good
Things that I have problem with:
MAF sensor is not working
All lambda/o2 sensors showing fault codes
I have never lost any oil as the electric oil level sensor is showing max.
Fault codes:
002CA3
002CA2
      01-31-2022, 01:36 AM   #2
F31B48
F31B48's Avatar
278
Drives: BMW G21 E61 LCI
These engines are notorious for worn valve stem seals causing blue smoke from the exhaust. How do you know the valve stem seals are good?
      01-31-2022, 03:42 AM   #3
nuke21
17
Drives: 09 328i
where is it smoking from? the exhaust or under the hood. I had a "new" valve cover gasket but noticed smoke at idle at a stop light coming from under hood. after better inspection I noticed the rear bolts on the valve cover were not tight so I torqued it and it went away. Scared me and my date at the stop light seeing this though. Stunk too.
2009 328i
      01-31-2022, 11:00 AM   #4
Camery
Netherlands
20
Drives: 2007 E90 318i
2007 BMW e90  [0.00]
My car had the same issue, N46 318i.
Idle the car for a few minutes and then step on the gas (in neutral) somewhat hard.
If there is blue smoke coming from the exhaust it is 95% valve stem seals and/or piston oil scraper rings.
I agree with the above, how can you be sure the valve stems seals are good?
I don't think a defect could be seen by eye, oil seeps trough the smallest of gaps.
My car had both possible suspects replaced and I am now blue smoke free.
