01-27-2022, 07:19 PM | #1 |
32
Rep 30
I live in Ontario, where we're having a particularly bitterly cold January for my first winter with my 45e, so I thought I'd share my observations.
First, I'm so glad that I got my Level 2 charger installed just after Christmas. I would NOT want to leave home without a fully charged battery every morning, because I'm LOVING the pre-conditioning! It only takes a few minutes to take the chill off before I get into the car. Leaving the garage is no problem at all. Battery range usually gets reported as 40 or 45 km. But don't count on it—cabin heating will drain that much faster than air conditioning, to my surprise. I guess everything about electrics is the opposite of ICE, including the impact of heat vs cooling on efficiency. I'd estimate the actual range is close to half what it would be in the summer. I have Electric Individual set as my default mode. On extremely cold days, after a day parked at work (about -16C or so) I will get a message that says it isn't available for "system reasons" and it will put me in Hybrid instead, starting with a sliver of power available regardless of the level in the battery. This will cause the ICE to kick on with little or no pressure on the gas. But this lasts only for a few minutes—I assume the ICE is warming the battery, which then rises to full power. All told it's still a great fit for my lifestyle, ie, a short commute to work, allowing me to do almost all driving electrically. And given the lack of infrastructure locally I'm very pleased to have an ICE available. Also loved having my first 4wd vehicle when I had to pull a trailer in a snow squall recently! |
01-27-2022, 07:32 PM | #3 |
32
Rep 30
LogicalApex2027.00 |
01-27-2022, 07:37 PM | #4 | |
2027
Rep 2,951
Drives: 2020 BMW 530xe
https://g05.bimmerpost.com/forums/sh...1&postcount=16 But glad you're enjoying it. Preconditioning is the gift that keeps on giving. Even made me question the value of paying for the heated steering wheel on my car. |
Quaze2231.50 |
01-27-2022, 08:02 PM | #5 | |
4719
Rep 8,789
Drives: eVeRyOnE mAD!
the "systems reason" and "HVAC deactivated" messages are completely different. don't confuse the two. a) the first deals with the HV battery being incapacitated due to extreme ambient temperatures affecting its operation regardless of charge level. this is well covered in the few threads about the 45e in extreme cold countries. owners stated the ICE turns on at the outset, as described by the OP. (so far, a 45e has never been reported to operate this way in extreme heat.) b) the second deals with the HVAC system being incapacitated due to a discharged HV battery. again, two different situations. steering wheel heat is one of my favorite features. this was something I couldn't get in my Audis the last 11 years because it was deleted with Sport trims. i love me some hot hands and often ran errands in the winter using my wife's bimmers since 2008 because of it lol |
Quaze2231.50 |
01-27-2022, 08:35 PM | #6 |
3209
Rep 6,881
Again, there are NO heaters in the batteries of the 45e. Drawing some power out of them will warm them some as will putting some power into them, but it cannot push power in if they're full already.
In every mode, there will be some EV boost, regardless of the battery level. It may not go into electric mode initially or literally move entirely on battery power, though. Not all BMW PHEV and EV platforms are the same, and the 45e is the latest PHEV version that isn't used (yet) on all models. So, trying to make comparisons between different series may not be valid. At the top of the forum, there are some files that describe the system. |
Quaze2231.50 |
01-27-2022, 08:59 PM | #7 | |
32
Rep 30
01-27-2022, 09:21 PM | #8 | ||
2027
Rep 2,951
As I can precondition my car on a day when it is 100F outside and get into a cold car that will then activate the ICE to get it to a safe temperature for driving... Quote:
I'm not saying there is a dedicated heater for the battery on either car... I'm saying the car heats the battery in extremely cold temperatures. Since this isn't covered in the manual or technical documents for either car (only cooling is) it is something we're left to guess how it actually does this. I have no guess on exactly how it is achieved. But that's why I shared the photo I shared in that thread. Of my battery being 100% already. My ICE running to "warm it" and it showing no energy going into the battery (you can't charge an already charged battery). I'd bet a beer that if the OP set his 45e in Barrie, ON to be 100% charged when he parked it outside of his work at -16C or so he's been encountering. He would turn his car on and get the same message he noted in his original post. With his ICE running for "system reasons" temporarily. Even though his battery has no capacity for being charged. I am only so sure that BMW hasn't removed these features because they would be a pretty significant regression in functionality if they did. As it would put extreme demands on the PHEV battery in those temperatures (Li-Ion really performs poorly when cold). Since our cars are a combined ICE+EV power output if they allowed this regression it would mean extremely poor EV power until the battery got warmed up naturally. Meaning owners in cold climates would be left complaining about how weak the cars are when it is cold out. But if I had to guess how they are doing it. They are running the AC compressor to warm the battery and everything is happening over the refrigerant lines. Since those can be at temperatures separate from what we would prefer. Last edited by LogicalApex; 01-27-2022 at 09:37 PM.. |
01-27-2022, 09:46 PM | #10 | |
4719
Rep 8,789
HV battery unavailable and HVAC deactivated aren't the same thing. |
4ML INC65.50 |
01-28-2022, 06:14 AM | #12 | ||
32
Rep 30
45e21153.00 |
01-28-2022, 06:17 AM | #13 | |||
32
Rep 30
01-28-2022, 01:59 PM | #14 | |
66
Rep 116
01-28-2022, 03:57 PM | #15 |
3209
Rep 6,881
The computer will shut preconditioning off after about 30-minutes on the PHEV, and 15-minutes on the ICE. Depending on the ambient conditions, it may be comfortable in less time than that. In the winter, if the vehicle is parked outside, preconditioning makes removal of snow and ice MUCH easier.
01-29-2022, 04:14 PM | #16 | |
66
Rep 116
So, I'm hoping - if I pre-condition for about 8-10 minutes - that should be good enough - maybe? I just want the chill out - I like slightly lower temperatures anyway. |
01-29-2022, 04:18 PM | #17 |
3209
Rep 6,881
If you really leave at the same time, setup a departure time, and you can select the days of the week you want it to occur. If you want to do it so it's warm when you leave work, you can set a second one for that time as well. There are three scheduled slots, and then an on-demand one that starts when you activate it.
You can set the climate rules to enable the seat heater (if you have that option) and heated steering wheel as well. In the summer, it would use the a/c system, if needed. |
4ML INC65.50 |
01-29-2022, 04:20 PM | #18 |
4719
Rep 8,789
LogicalApex2027.00 4ML INC65.50 |
01-30-2022, 09:24 PM | #19 | ||
32
Rep 30
4ML INC65.50 |
01-30-2022, 09:26 PM | #20 | ||
32
Rep 30
4ML INC65.50 |
01-31-2022, 04:56 PM | #21 |
66
Rep 116
