01-06-2022, 01:49 PM | #1 |
59
Rep 211
Need new motor @ 32k miles
Brought my car to get serviced because the check engine kept on going off and on multiple times, car has 32k miles and my SA called me to tell me needs to replace motor. Anyone dealt with this before?
01-06-2022, 02:35 PM | #3 |
4067
Rep 4,988
That was the whole conversation? Any details?
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold) 2018 F80 ZCP TB|SS (sold) 2015 F30 335 AW|CR (sold) 2015 F31 MG|CR (sold) 2011 E90 JB|Oyster (sold) |
01-06-2022, 02:47 PM | #4 |
2281
Rep 3,305
What year? Does it have a sun roof?
I am guessing no modifications.... An engine swap is not actually a big deal for a dealer. That was a common occurrence on the 750's for several years. A friend had one (before his prior M5) that needed an engine swap TWICE. Mike
01-06-2022, 03:05 PM | #6 |
367
Rep 1,202
Sorry but... found this hilarious
2021 M5 Competition Marina Bay Blue/ Individual Tartufo/ Individual Piano Black Trim. Took delivery 11/27/2020 2017 X5 ///M Silverstone/Mugello Red/ Carbon Fiber Trim Turned in 11/27/2020 |
RAUDERRIPPER886.00 |
01-06-2022, 03:54 PM | #8 |
59
Rep 211
All he said was they ran test and a cylinder was misfiring, need to replace motor and BMW authorized it.
01-06-2022, 03:55 PM | #9 | |
59
Rep 211
01-06-2022, 03:58 PM | #10 |
59
Rep 211
01-06-2022, 05:40 PM | #11 |
4067
Rep 4,988
I wouldn't say common in the general sense. I think the incidence is low, but also probably more common than most realize, even on cars without tunes.
Weird that a misfire alone would dictate a new engine, but could be the result of a number of things, so I guess all's well that end's well
FSHNGRY2391.00 imperfectluck434.00 |
01-06-2022, 07:24 PM | #12 |
204
Rep 386
Motor swap seems quite drastic for a simple case of misfiring but it could be a mixture of issues which resulted in the need for an entire motor swap.
It seems a rather good deal to have a brand new motor after using the vehicle for a period of time.
Born in M Town
01-07-2022, 05:53 AM | #13 |
2281
Rep 3,305
Well well well, no sunroof? Not an M5. Sorry. Pretender with plastic roof. Engine swap will be fine, don't sweat it.
Mike
01-11-2022, 11:44 PM | #14 |
1725
Rep 1,921
Drives: 2023 M5C
What was the pertinence of having a sunroof??
01-12-2022, 08:19 PM | #18 |
580
Rep 650
01-20-2022, 01:44 AM | #19 |
Rep 19
SOLUTION
Hi, m5 f90 are known for the problem with misfiring .. the whole problem is in the sparks plugs and coils - especially if the spark plugs haven't been changed before (in 32K miles it is time to change them anyway) ... usually there is a leak of cooling fluid due to a bad design of a top cap of the cooling fluid tank ... then, due to high pressure under a load a bit of cooling fluid leaks/burst a bit and the liquid goes to spark plugs and coils around causing corrosion of the coils ...
Then during driving when you hit the gas pedal, the engine falls into limb mode and engine light turns on ... Your SA diagnostics then says there is a misfire at certain valves ... so what is the solution? If you notice there is a white plaque/dots at the engine cover, that is a cooling fluid and it means it got into spark plugs/coils area. Just change the spark plugs and coils and the car should be ok. I also had this problem with misfiring my m5 and other guys here as well .. SA are also advised from BMW central (at least here in Europe) to replace cooling fluid tank cap Let us know if it helps P.S. Somewhere in my phone I had also videos of the car getting in the limb mode but I think it is not necessary to post it here ... if the car is out of warranty I think the price for changing the spark and plugs should be around 1200 USD. Cheers, Petr |
F30Andy1787.50 |
02-17-2022, 12:44 PM | #20 |
2464
Rep 3,803
Maverik2594150.50 |
02-18-2022, 12:44 AM | #21 | |
1659
Rep 2,406
2022 M8 Comp GC, 2021 AMG GT53, 2022 X5M Competition, 2021 X7 40i, 2019 M5, 2018 M550I, 2017 Audi Q7, 2014 M6 GC, 2013 Mercedes CLS550, 2011 750LI, 2008 M6 Cabrio, 2008 Porsche Cayenne S, 2004 Mercedes SL55 AMG, 2003 Mercedes SL500, 2000 Mercedes CL500, 1993 Lexus SC400, 1989 525i, 1985 318i
02-18-2022, 12:31 PM | #22 |
59
Rep 211
Car never went to limb mode but I believe 2 years ago they replaced the coil because of the cooling fluid. It is what it is as long as everything was under warranty.
