12-27-2021, 04:58 AM | #1 |
913
Rep 1,156
Change from run-flat tyres?
I know this has probably been discussed to death on various threads, but wanted to get done definitive answers from people who have made the change please.
What did you change from and to? Did you notice a discernible difference in the ride quality? On reflection, was it worth the money? I'm running Pirelli P-zero PZ4 run-flats, which I think are quite widely known for their harsh ride even when comparing with other run-flats. |
12-27-2021, 08:28 AM | #2 |
110
Rep 153
1. Yes it has, to death
2. Most have gone to Michelin PS4s, seems to be the gold standard in summer tires for cars like these. I just changed to a high performance all season due to my climate, the Conti DWS 06+, amazing tires for what it does. 3. Nearly whatever choice of regular tires you go with, you will notice an improvement in ride quality for sure, cost, longevity, noise, etc… 4. If you really want to make it worth it use your runflats through the season then change in the summer time, to get a little more life out of them. In the end it will be worth it.
2020 BMW M850 Gran Coupe
2019 LR Discovery HSE 2009 BMW 650i Cabrio 1999 Mercedes SL500 1980 Mercedes 450SL |
cfm56d7b5922.50 |
12-27-2021, 08:39 AM | #3 | |
254
Rep 271
Also added this to the trunk: https://www.amazon.com/ResQ-71-063-0...a-813603528918. It fits really well in that pocket on the right side and I used stick on Velcro from Home Depot to get it to stay through my f1 driving 😂 |
12-27-2021, 01:45 PM | #4 | |
5923
Rep 10,307
12-27-2021, 06:48 PM | #5 | |
Not a good Canadian sheep!
1283
Rep 1,116
Now you can't get it perfect either as of course winter can vary from day to day. If I was in a snow zone I'd look for a more knobby type tire. Something with some snow flinging ability. Something with some ability to move snow out of the way if it's deep. If you deal with a lot of snow then don't go as wide as the stock tires. Just a bit less than stock width. A bit taller tire is good then as well. If you see very little snow but more ice go for an ice specific tire. It can be the same as stock size. Ice tires move less snow but have more contact patch overall. For instance if you live in Toronto you need mostly an ice tire. Not much accumulation usually (usually). North of Toronto a snow tire can be more suited. Two different applications/uses of tires within 100 miles of each other. Honestly the M series is not the best winter car choice. Mines in the garage for the winter. On my Saab which i do drive in winter AWD I chose the new Michelin X Ice tires. New for me this year and I think new this year for the tire too. Highly rated tire. Good so far. I'm able to matt it pretty good with a ton of traction still. So far the best winter tire I've had on the car. But it very early to tell still really as we haven't had a lot of winter yet here. Last edited by M8Bimmer; 12-27-2021 at 07:23 PM.. |
