12-15-2021, 06:55 PM | #1 |
5330
Rep 1,912
Basement Water Mitigation Legit?
So I have a basement for the first time. Only been here since June, but one day when we got a lot of rain very quickly I noticed water in the basement. I believe most of the water came from a drain hole in the floor (which looks to have a rubber cap on it). Maybe a very small amount came from one of the walls, but hard to say as I found the water later on and it might have subsided some back into the drain by the time I saw it. However I’m pretty sure the vast majority came from the drain.
So I figured I better deal with this now before the rainy season comes and we get some more monsoon weather. Called a company that’s suppose to do basement water mitigation. They seemed to have good reviews on quick examination. Anyways they recommended some gutter type thing they put under the foundation where the wall meets the foundation and connects to a sump pump that pumps it out. Now part of the basement has a finished room in it. So the quote did not include anything in there (as it would be torn up) or the other side of the basement where I did not see any water. He’s telling me $5,300. So is that shit legit or is it some kind of bs scam? I’m thinking of taking the rubber cap off the drain and dump some cement in that bitch and see what happens. However never having had a basement I obviously don’t know what I’m doing. Anyone have one of these systems or know anything about this? |
12-15-2021, 07:27 PM | #2 |
Weirdo
433
Rep 182
Sounds like the company is talking about weaping tile. Search around using this, you'll get a ton of information.
Can't comment on the cost, but weaping tile does work. If you go for it, I highly recommend a backup pump above the other... (with check valve) If they're going to dig around the house, install the weaping tile, and then connect to a pump it's a lot of work. Last edited by Frostynorth; 12-15-2021 at 08:23 PM.. |
dreamingat30fps5330.00 King Rudi13157.00 |
12-15-2021, 07:33 PM | #3 |
7933
Rep 1,923
Second what frosty said. French drain / weeping tile does work. But ultimately best when the house is first built as they can incorporate a pit with a sump pump in it that continually pumps water away and keeps the basement dry. If they are digging all around the house that will be expensive. But not sure how they are going to incorporate a pit with a sump.
Good luck! |
12-15-2021, 07:54 PM | #4 |
Free Thinker
17032
Rep 7,456
A basement drain can be handy if it isn't causing problems. If you ever decide to put a dehumidifier down there, floor drains are perfect for draining the dehumidifier. But as you say, if it's just a "drain" into the area directly under the basement and allows ground water to seep back in, that's a problem.
Are your gutter downspouts just dumping water next to your house? Or are they connected to drain hoses to move the water away from the house?
dreamingat30fps5330.00 vreihen1615405.50 |
12-15-2021, 08:19 PM | #5 |
4498
Rep 694
French drain, they were big in Jersey…. It’s legit
dreamingat30fps5330.00 |
12-15-2021, 08:39 PM | #6 |
3076
Rep 5,577
though I know numerous people who've had french drains installed and they did not work successfully.
did the company specify a battery powered sump ? (would a battery powered be the right type ?) Did the company say if it's subsurface groundwater rising issue or a surface water flooding issue leaking into the home ? Or a combo of both ? |
12-15-2021, 10:29 PM | #7 |
5330
Rep 1,912
So basically my understanding is it's like a French drain but inside the basement. They cut a trench all around the perimeter of the basement cement floor. Install some kind of channel thing in there that leads to another pit they dig inside the basement to a dump pump. Part of the cost includes adding a dedicated breaker for the pump so it's electrical.
They will only do basically half the basement as the other half is finished and had no water intrusion on that day (that I could see). The guy said he believes that should take care of it, but it's hard to trust the guy selling the stuff. He said the perimeter drain should stop the floor drain from overflowing but they would run the channel to where the drain is to be safe. So $5k MIGHT solve the issue or it might not and might require another $5k or who knows what to do the other side. He said the issue is definitely ground water coming in. It rained a lot in the summer but only time it came up was the day it rained a LOT in one day. The house is on the side of a slope so the front of the house is at ground level with front yard and the basement is ground level with the yard. So the basement goes more below ground the further in you go. The drain in the floor seems to serve no purpose and they put a rubber stopper on it (obviously didn't work). That's why I'm thinking cement that mofo up. If that doesn't work I could still fork over the $$ at that point. |
12-15-2021, 11:16 PM | #8 |
116
Rep 144
Always start outside first then move inside. First thing you want to do is make sure that all your downspouts are clean and dropping water at least 3 feet from the house. Then make sure that your house landscaping is graded away from the house. Then check this hole in the basement. Without looking at it I wonder if it is a sump pit.
If this is a single family house with a yard you want the exterior french drain into a sump pump. Needing an interior french drain is very rare and really is only used when you cannot install one outside because the house is too close to another one. |
12-16-2021, 07:26 AM | #9 |
3850
Rep 2,874
You didn't get a consultation on drainage issues, you got a sales pitch for their favorite procedure. That inner drain is basically a last-ditch approach that catches intruding water and pumps it out before it builds up too far; you still have all the problems with humitidty and water damage to foundation. And unless your baseement is only half underground, only doing half of it is really inadequate. It is bettter than nothing, but nowhere near as effective as the more expensive outside drainage. Figure out if the water is coming up the drain, or in thru foundation/walls (asking neighbors if they got water up the drains as a good indicator if there was a backup), and go from there. Sometimes the city needs to clear their drain lines, but if you are on septic/leach fields then it is all basically groundwater intrusion. Either way, it is good to make sure groundwater and roof runoff is going away from the house.
12-16-2021, 07:38 AM | #10 |
317
Rep 395
VERY IMPORTANT - as already suggested, work on the outside drainage first. Make sure gutters dump far away from the house, and during a rainstorm look at any other drainage areas to see which way water runs. Sometimes it’s as simple as adding a landscape timber or other barrier along a driveway or sidewalk to ensure water runs away from the house.
When was this house built? Adding interior French drains and a sump pump will probably work, but are an expensive solution for minor water intrusion. Most newer homes with basements already have the drains and a sump pump well, but might not have a pump installed. |
dreamingat30fps5330.00 DETRoadster11466.50 |
12-16-2021, 08:39 AM | #11 | |||
5330
Rep 1,912
I guess next step is to open that drain and see wtf is going on in there. I havent done it yet because I figure I’m probably going to break the rusted out cover thats on it currently so I need to have the time/plan to cover it back up when I’m done. There is another drain exactly the same with the same cover maybe 15ft to the side of that one but no water came in through that one. |
12-16-2021, 08:40 AM | #12 |
Space Force - 4 Star General
11467
Rep 3,264
As others have said, make sure your roof drains are depositing water as far from the foundation as possible. Start there before you go digging up the basement. I had a problem corner at my house that flooded when we got heavy rain. I ran the downspouts into a small cistern with a sump pump in it. That pump pumps it up, out, and into the municipal storm water collection system. Works like a charm. No flooding. No digging up the basement.
King Rudi13157.00 dreamingat30fps5330.00 |
12-16-2021, 08:43 AM | #13 |
11467
Rep 3,264
So to be fair, he had the right solution already prepared because it's pretty much the same solution for every house. You either have storm water runoff from the roof causing localized flooding that enters the house, or, the general water table rises and hydraulic pressure forces it in. Either way the solution he has the offer is the same: Weeping tile around the house and a sump pump.
12-16-2021, 08:45 AM | #14 | |
8912
Rep 4,107
I was considering these leaf covers for our home but did some research and saw way too many stories of this issue...
2021 X3 M40i
1974 2002tii, Inka, 5 sp manual BMWCCA # 327475 |
12-16-2021, 08:55 AM | #15 |
341
Rep 441
A fun watch. |
12-16-2021, 08:59 AM | #16 |
6537
Rep 3,034
I hate to be that guy but this is a world of hurt man. Water is an absolute SOB and this has potential to be very expensive and incredibly frustrating. Good luck sir.
12-16-2021, 09:10 AM | #17 |
1082
Rep 949
As other have mentioned. Make sure gutters are ran correctly and far away. If you are getting it on one side, that system works. I have a rental in New Jersey. 80% of the basement is finished. One day the area rug was soaked. I had water coming in the block wall. They came in, did exactly what you are saying, cut the floor and installed pump. Ran down a 20' wall and 6' up each connecting wall. It was 4500 bucks and have had no issues. People saying do the outside first, F that. Try this first as it will be a fraction of the cost. You will be 20 plus G's most likely for the whole outside. Just my opinion.
12-16-2021, 09:33 AM | #18 |
13157
Rep 1,965
This thread has made me anxious.
12-16-2021, 10:13 AM | #19 |
18078
Rep 9,381
We had a related problem on the baseball fields. Dugouts were cement lined, and below grade. There was a drain in the middle, but one dugout always filled with water. Turned out, once we cleared the drain properly, no more flooding.
Also possible the PO MAY have covered the drain for times when a sump wasn't installed |
12-16-2021, 10:40 AM | #20 | |
Free Thinker
17032
Rep 7,456
https://www.amazon.com/gp/product/B01MYTHWK4/ I have this exact one and it works well. I used it to inspect our chimney flue.
12-16-2021, 10:51 AM | #21 | |
18078
Rep 9,381
12-16-2021, 01:22 PM | #22 |
7436
Rep 11,846
Drives: MY24 G01 AW Msport
what you currently have under that drain is man made drywell, its a pit thats collects water. Most of them are made of sand, rocks, gravel. The water should disperse into the ground slowly...but during heavy rain, or rainstorm- the water will back up into floor drain.
the solution is to redirect water into the sump pump to avoid flooding inside the home. the sump pump and basin with controls can be pricey, some come with battery backup cost is north of $2k..plus all the electrical wiring and waterproofing. |
