12-03-2021, 05:07 PM | #2 |
369
Rep 467
I DIY'd the front and rear differential fluid at 45k miles on my car. The front and rear diffs take different fluids so be mindful of that. Also did the xDrive transfer case the following day and the ZF 8HP transmission fluid and filter at 48k miles myself which is a little more involved but do-able if the car is on jack stands or lift. Plenty of videos and DIY tutorials out there to build your confidence. That BMW lifetime BS is just that. I don't drive the car too hard so your fluid change intervals may vary. Oil changes every 5k miles, brake fluid flush was done when I did the brakes this year. Had the dealer do the coolant flush and pressure check with a discount coupon this year as well. The price they did it for didn't make it worth it for me to do it myself.
12-03-2021, 08:03 PM | #3 |
383
Rep 923
Drives: G12 750Li
Did the exact same as runner.
52k miles and it wasn't too difficult since I was doing all my maintenance then on stands
-2017 G12 750Li "Giulia"
-2014 F32 428i Xdrive "Bella" -2013 E82 128i "Austin" -2000 E38 750iL "Stella" |
12-03-2021, 08:48 PM | #4 | |
28
Rep 74
The fluids are different, but can you be specific? Weight for the front and GL4 or GL5? Weight for the rear and GL4 or GL5? I need to get this info pinned down to exactly what it should be and put into my maintenance notes. Thanks! |
12-03-2021, 11:50 PM | #5 |
126
Rep 326
I used 75w-90 GL5 for the front and rear. Lots of forum members have used that so far without problems, including myself.
And I change mine every 30k.
If you can imagine it, you can achieve it.
If you can dream it, you can become it. |
12-04-2021, 05:09 AM | #6 | |
417
Rep 919
I got all mine from FCP euro--close to $400 for everything. I still have to make the change though...coming up on 100k miles.
12-04-2021, 05:22 AM | #7 |
2467
Rep 5,457
Drives: F30
Every 60k for me. Done it twice so far on two different F30s.
Word to the wise: a nice big fluid syringe made the job much easier the second time. Made a mess the first time around using the HF manual fluid transfer pump. |
dmaxdmax417.00 |
12-04-2021, 07:20 AM | #8 | |
369
Rep 467
12-04-2021, 12:39 PM | #9 | |
28
Rep 74
a) Can't use GL5 in either the front or rear (can't remember the reason - something to do with oxidation) b) Have to use OEM fluid, the Redline won't allow the diff to last it's full potential. I plan on keeping this car a long time so this is important to me. Thanks |
12-04-2021, 07:22 PM | #10 |
417
Rep 919
Mine shows Hypoid Axle oil G1 in the rear and G2 in the front diff and DTF1 in transfer case.
12-04-2021, 08:04 PM | #11 | |
28
Rep 74
EDIT: Correction - G1 is GL4, so I'll just use Redline 75W85 GL4 for that and Redline 75W85 GL5 for the other. There must be brass or something that can corrode if they are using GL4. |
dmaxdmax417.00 |
