TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > AWD trifecta issues
      11-23-2021, 11:58 AM   #1
ezadel
Drives: 328xi wagon
AWD trifecta issues
Hello everyone:
I have been reading those forums for a while and finally decided to post. I have an E91 2008 328xi 120,000 miles ( recently bought)
I got the trifecta lights AWD, DSC, ABS
Got INPA and ISTA/D and got the following codes: 578E, 54C6, 55C3, 54C8, D104, 5F39, D904, E104 and E5C4
so I thought by replacing the transfer case servo motor and the transfer case and transmission fluids.
Here's what I am worried about I hear conflicting opinions about transmission and transfer case fluid changes.. some say that changing these fluids will ruin my transmission and transfer case (because I have the wear codes and they probably never been changed)...
should I change the fluids?
Any other advice on my codes/repair plan?
Thanks a bunch and looking forward to hear from you
      11-23-2021, 12:11 PM   #2
Brian86
Brian86's Avatar
638
Drives: e36 M3, e91 325xi, N50 Xterra
Changing fluids won't ruin anything. That's silly.
If it's worn out, it's worn out. New fluid or old.
I think there was some talk on the general forum about not resetting adaptation values on the transmission because it takes an eternity to re-learn, and the system will 'adapt' more swiftly than it will 'relearn'
This is probably correct. My engine took like 3 weeks to rev and drive right after I reset all the adaptations shortly after I purchased it and after doing a bunch of maintenance.
Transfer case adaptation resets are uneventful. You won't even notice it happening. They are required when changing mechanical parts otherwise the computer will continue to be angry with you.
Sometimes a bolt is just a bolt.
      11-23-2021, 12:15 PM   #3
ezadel
Drives: 328xi wagon
Thanks. I ll change both fluids the servo motor and hope for the best
Do I need Ista/F to readapt? or can I used ista/D or Inpa. What is the procedure for resetting Transfer case on ista/D
      12-01-2021, 09:26 PM   #4
ezadel
Drives: 328xi wagon
Help. I just changed servo motor and TF oil still has same error. I tried to rest the transfer case but ista D said function could not be perfomed without fault. Please help. I dont know what to do now
      12-09-2021, 10:41 AM   #5
andy_06xi
74
Drives: 2006 330xi
Could be a bad wheel sensor
A bad wheel sensor is a common problem and will cause this. Without a good scan tool -- it will be difficult to identify which one is the problem.
I used a Foxwell scanner to identify my problem and it correctly pointed to the left front sensor. Swapping a sensor is pretty straightforward. Sometimes the sensor ring develops rust and takes out the sensor -- so cleaning the sensor ring is a good idea as well.
      12-13-2021, 10:55 AM   #6
m_thompson
m_thompson's Avatar
Drives: M-Sport 128i, 328xi, 3.0CS
2009 128i  [0.00]
1972 3.0CS  [10.00]
We also had the lights on the dash. We cleaned the reluctor ring and replaced the ABS sensor. That fix lasted about two years. This time we had to replace the axle and the sensor. We used a GKN axle because it was 1/2 the price of one from the dealer.
'09 128i - Black Sapphire Metallic\Coral Red\Glacier Silver\N51 DISA\6MT\Navigation\Premium\M-Sport\Heated seats\Xenon\Headlights\iPod\Smartphone\Euro Delivery
      03-14-2023, 08:16 PM   #7
ezadel
Drives: 328xi wagon
I realized I never updated this. Turned out both my trasnfer case and motor were bad. I bought a used transfer case a new motor put them in my self ...Replaced motor first but the gear inside the transfer case itself was broken and not meshing with servo motor. Tried the old servo motor and it was bad probably due to trasnfer case itself breaking it. Changed TC fluid and everythimg been working for over a year now
      03-14-2023, 08:17 PM   #8
ezadel
Drives: 328xi wagon
Also I replaced my transmission fluid/pan/filter and was uneventful
