11-22-2021, 10:15 PM | #1 |
90
Rep 176
2011 x28i Laggy throttle and slipping feeling
I’m hoping someone who has experienced the same thing i am experiencing will chime in here. 2011 x28i with 154K. Here’s the scenario:
About a month ago i was pulling on to the interstate gathering speed up about 50mph and the X3 had what i thought felt like a misfire? Maybe a REALLY hard shift? A slip in the transmission? It did it once and i continued on cautiously. The next day, car was fine, I put it in manual shift mode and it is great. So iI started reading and googling and decided it was time to do the front&rear diffs and the Transfer case fluid. Ordered the stuff from FCP and a couple hours in the garage all the fluids had been changed. Art this point i reset the VTG. Now, after that was done..it feels like the gas pedal is very laggy…it seems as though the X3 is shifting at different points…and the car has been fine for a month until today…..on the way to work at about 45 mph, another big hard something…..i drove easy to work and when i left, car seems fine. Has anyone experienced something similar? I was thinking about changing out the transfer case fluid again just for peace of mind,,,… |
11-24-2021, 01:53 PM | #2 | |
1623
Rep 2,036
11-25-2021, 07:28 PM | #4 |
90
Rep 176
UPDATE - Today i was going to family dinner and I had a couple of hard shifts and then a Transmission Malfunction came up……..I ran ISTA and itt came back with these codes:
11-26-2021, 12:32 PM | #5 |
160
Rep 350
I don't know what your drivetrain issue is. I do know C90D60 AUC sensor isn't relevant. That's an air quality sensor located by your cabin air filter. I replaced mine this past summer.
1986 Delphin 528e - Roof rack equipped lumber hauler.
2008 Platinum-Beige X3 3.0si - Current project 2012 Alpine White X3 xDrive35i - My new snowmobile. 2020 Estoril Blue 440i xDrive cabrio w/MPPSK - This car is a blast to drive. |
12-03-2021, 01:50 PM | #6 |
626
Rep 1,044
Drives: 2018 X3 M40i, 2012 X3 Xdrive35
If you are experiencing a shifting problem, I would do a tranny fluid and filter change before the transfer case and differentials.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131 2021 SQ5 |
