F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > USA - NY / NJ / CT / PA > Passing Philly Inspection with Modded Cars?
Studio RSR
      11-16-2021, 01:35 PM   #1
McGyv3r
Drives: 1989 325i & 2014 335i
2014 BMW 335i  [0.00]
1989 BMW 325i  [0.00]
I'm considering a move from San Francisco to Philly at some point. I'm pretty well versed on the rules out here for any kind of driveline modifications, but I'm having a tough time figuring out the SE PA rules. I'd like to get a better understanding of what kind of issues I may face before buying stuff that I may have to remove every year.
  1. I've got a 1989 325i that's going to get worked over to a high compression 2.9L, but will look stock to anyone. Stock ECU, intake, possibly getting headers. It should be tuned well enough to pass smog in CA with the stock cat. I assume this car will be fine.
  2. I plan to get an e30 touring (don't care about the engine), which will get a built m20 of some displacement and a turbo. It's going to be heavily modified; MegaSquirt ECU, turbo, custom exhaust, etc. I've got 90% of the parts BNIB sitting on a shelf in my garage. What kind of options do I have for registering the touring as a weekend driver?
  3. I have a 2014 335i that currently has a CP and bm3 tune. Soon to have an intercooler. I'm considering a TIC, Turbo Inlet, and catted DP. Would the intake pipe stuff fail a visual? I assume they check OBD readiness, so will I need to flash back to stock and lock the ECU? Could I pass the test with a catted DP assuming the Cat monitor was "not set" instead of "failed"? Am I looking at putting the stock cat in once a year or getting a high-end catted DP to pass?
I appreciate any info/guidance.
      11-18-2021, 10:01 AM   #2
vgore
vgore's Avatar
73
Drives: 2015 328xi
As long as you don't have any check engine light on, they can pass PA nspection.
      11-18-2021, 10:25 AM   #3
McGyv3r
So no OBD scan, no checksum like they're doing in NY?
No visual? No tailpipe sniffer?
f30post
