10-28-2021, 07:49 AM | #1 |
30
Rep 41
Center Armrest Vibrations Driving Me Crazy!
It's so annoying that I'm forced to leave it open (vertical) because at low RPM in 2nd, 3rd, & 4th gears the deep exhaust note makes it buzz non stop.
Only other solution is to put all the weight of my right elbow on it which is starting to hurt. Anyone have the same issue, and if so, what did you do to resolve it? Car is M2C manual and i have OEM downpipes/cats, AA single mid pipe, and AA valved axle back muffler. |
10-31-2021, 11:15 AM | #2 |
Rep 16
I have completely stock '21 M2C, and have zero rattle. I'd look at taking it in, but unless you have a nice dealer, they'll just blame the exhaust mods.
You might be able to fix descreetly with a bit of well placed black foam though. |
11-06-2021, 08:11 AM | #4 |
290
Rep 408
Perhaps the midpipe is making contact with the center brace under heavy load, which is leading to buzzing noises and vibrations into your cabin. The clearances between the midpipe and center brace are tight, so I would recommend re-examining and adjusting your exhaust to make sure you have adequate clearance between the midpipe and center brace.
11-14-2021, 07:19 AM | #5 | |
97
Rep 110
Bill
2020 M2C 6MT SO |
11-14-2021, 08:27 PM | #6 |
2169
Rep 2,353
BSM ///M2cs, 6spd
08-30-2022, 10:09 AM | #7 |
30
Rep 41
So its been months. I made sure the exhaust has good clearance on all sides.
It's clearly not that. I basically gave up. Started driving faster and more aggressive. The higher/louder the RPM, the less i hear the noise. Until my wife gets in the passenger seat on Sunday and notices the rattle/vibration. After asking what's causing that noise, she very casually reaches to the arm rest, lifts it open, and places her finger down on the stupid wireless charger that i never ever use. The second she pressed down on it, it stopped! Now that its diagnosed...how the hell do i get rid of it? Has anyone removed the wireless charger from inside the arm rest? |
08-30-2022, 08:25 PM | #8 | |
7334
Rep 7,298
09-08-2022, 02:15 PM | #10 | |
380
Rep 166
https://www.ecstuning.com/b-genuine-...gaAonHEALw_wcB |
09-09-2022, 12:03 PM | #12 | |
380
Rep 166
https://f30.bimmerpost.com/forums/sh....php?t=1051389 |
09-26-2022, 08:22 PM | #14 |
17
Rep 92
Mine creaks if I rest my arm on it. Keeping it forward feels like it’s “too forward” and not natural.
I heard you can apply some dry lube to the hinges. Might give it a shot but for now I got use to it |
