10-24-2021, 04:04 PM | #1 |
Rep 24
120k maintenance - which parts should be checked?
Hello there,
I have a 2015 model F20 LCI 118i. 120,000 km maintenance is coming. I have a few questions; a) Which parts do I need to have checked? b) I have no problem with the gearbox, but is it still necessary to change the oil? c) There is no sound in the chain, is there a need for a change? d) I changed the spark plugs to NGK LASER IRIDIUM 20 thousand km ago. How many miles will it go? My to-do list; 1- oil change (bmw twin turbo) 2- replacement of all filters (bmw original oil filter - mann air and cabin filter) 3- replacement of all antifreeze liquid (castrol nf blue - pure water) thank u very much for your help |
10-25-2021, 12:11 PM | #2 | ||
1045
Rep 1,343
Address your manual, perhaps. Just for example, see page 252 ("Maintenance") here.
I would replace this point with brake fluid replacement (unless you did it recently: it needs replacement once in two years, AFAIK). |
10-25-2021, 12:15 PM | #3 | |
Rep 24
Hello there, Thank u very much for your help.. I have never changed transmission oil before. I haven't felt any problems so far. Gear shifts are flawless. But I was undecided when I saw that some people were having problems after the transmission oil change. |
10-25-2021, 12:24 PM | #4 |
1045
Rep 1,343
So don't do it then (if it's not supposed "officially")! I have a manual gearbox and couldn't care less about automatic, honestly.
10-25-2021, 01:02 PM | #5 |
Rep 24
