Mid-repair now - HELP - spark plug submerged.
10-22-2021, 07:21 PM | #1 |
2010 e90 335i 6MT, RWD, Msport
24
Rep 114
Hi y’all,
I’m a noob doing my first valve cover gasket and plugs & coils. I spotted an oil leak around plug 4 last week (had lost QT of oil in a month). As I loosened the first three torx bolts on the VC plug 4 got totally submerged in oil. I’m unsure of what to do next. VC is off. I’ll do the gasket now. But what’s the best path forward with this plug? PHOTO ATTACHED. Huge thanks y’all!!!
2010 e90 335i 6MT, RWD, Msport + Synapse Chargepipe w/BOV + AFE DC Intake + Catless DP's + ST XTA Coilovers + M3 front control arms + Index 12’s + VRSF FMIC + RB PCV + Phx Racing OCC + MHD tune Stg 1+ v.10.
10-22-2021, 07:46 PM | #2 |
1691
Rep 3,654
Plan A) Get a little syringe and try to empty it out as much as you can or you could even try to sop it up with a few little pieces of a shop towel.
Plan B) use a wet dry shop vac to suck it up Plan C) disconnect the fuel pump fuse and crank it over a few times with the plug removed and it’ll shoot the majority of it out |
19jdog86.50 |
10-22-2021, 08:53 PM | #4 |
369
Rep 423
Drives: 2007 E93 MT6
That's an epic amount of oil in your spark plug well, and it is really clear. Did you do an oil change shortly before the VCG job? Oil turns amber or darker pretty soon after being introduced to the engine.
BMW: Doing Amazing(ly cheap) Things With Plastic (crap) Since the E90...
10-22-2021, 09:00 PM | #6 | |
24
Rep 114
But I’ve not done a full oil change as that was done a couple months ago when I bought it. The rest of the oil on the valves is dark. So odd! |
10-22-2021, 09:01 PM | #7 | |
24
Rep 114
10-23-2021, 10:49 AM | #9 |
77
Rep 169
10-23-2021, 10:58 PM | #10 |
24
Rep 114
Everything was a huge success. Even got some nice torque gains with the new NGK plugs and Delphi coils. We’ll see how the VCG holds up over time. She’s running damn smooth right now.
Thanks for the help y’all. |
mainbearing1084.50 charlie_m77.00 |
10-24-2021, 02:36 PM | #11 | |
17
Rep 69
Drives: 2010 328i
Spark plugs torque spec is for clean threads. If you think to the same spec on oiled threads you will over-torque and risk stripping the threads, which would really suck. Over time, the oil in the spark plug threads will burn off leaving carbon, which could cause the plug to seize. You also foul the cat. As soon as you turn over your engine, that oil gets sucked into the exhaust and soaks your cold catalytic converter. It then burns off once the cat heats up, and should be ok since it's not that much oil, but still not great. Just suck it out with a syringe and hose or soak it up with shop towels. |
