10-09-2021, 03:47 AM | #1 |
80
Rep 70
Flex fuel Sensor for JB4
Hey guys, I dunno if it has been asked already but is there a jb4 flex fuel sensor kit for the G80 platform? Does the F80 one work? I'm looking to run e30 blends and stuff but I'd feel much more confident being able to see the ethanol content rather then rely on my (poor) math/calculations using apps.
What's the most ethanol we can run on JB4 as well? I know some of the fastest guys are running an ethanol and race gas mix. I'm new to JB4/piggybacks so still trying to figure everything out. Edit - also I read elsewhere that apparently JB4 only seems to run most efficiently in comfort mode compared to sport plus, is that still the case? Just a rumor/not proven? Last edited by KevinMO91; 10-09-2021 at 04:07 AM.. |
10-09-2021, 06:29 AM | #2 | |
1630
Rep 1,279
Comfort/sport stuff is not an issue. There are definitely differences between the modes in how the car ramps up boost and this involves different modulation of the throttle, which you can see if you log. Possibly the car may overshoot less in comfort which results in less pulling back of the throttle values. But, there is no overall issue that makes comfort better than sport. Anyway with JB4 you can log for yourself and come to your own conclusions. |
10-09-2021, 07:05 AM | #3 | |
80
Rep 70
10-10-2021, 04:30 PM | #5 | |
648
Rep 494
10-10-2021, 04:41 PM | #6 |
517
Rep 570
Drives: '19 GLA45AMG(his) / '21 X3M40i
Only saw one for the S55
https://www.fuel-it.com/flex-fuel-kits-24/ Never mind. Is under the X3M/X4M menu: https://www.fuel-it.com/bmw-x4m-and-...lex-fuel-kits/ Now the question is, can the sensor and JB4 work together so that JB4 can select the correct map based on the ethanol fuel content registered by the sensor?
Currently: '19 GLA45AMG grey (his) & '21 X3M40i DGM (hers) w/ JB4@Map1
Previous cars: 2022 M4 xDrive in Mexico Blue with Silverstone/Black interior 2014 BE GTR FBO/e85 Last edited by GixY2K; 10-10-2021 at 04:47 PM.. |
10-11-2021, 12:44 PM | #7 | |
80
Rep 70
just sucks because there's a notice exhaust difference between sport plus and efficient even with the valves open. I have my flaps manually open and even in efficient with valves forced open you don't get any of the same noise as sport plus. It's really annoying. I kinda caved in to get the jb4, wondering if I should of just waited for a dedicated tune as the install of the jb4 was beyond annoying. Went super smooth except for the sensor under the driver side airbox. I ended up breaking the clip. I had to remove the entire sensor just to take it off and plug in the jb4 harness. So now I'm paranoid about that clip. I'm still waiting to try an e30 blend maybe that will change how I feel |
10-11-2021, 01:29 PM | #8 |
286
Rep 508
10-14-2021, 05:28 AM | #9 | |
648
Rep 494
