10-08-2021, 05:11 AM | #1 |
46
Rep 76
OPF Delete - Standard map
Hi all,
For those of us in Europe looks like there are a multitude of options now to delete the dreaded OPF and not trigger an EML without mapping the car. I have a Miltek EL OPF back system currently, has anyone had any experience in removing the OPF and mitigating sensors with Leib or other? Does the car run OK? Is the additional sound significant? Have you noticed any extra power with measurable results (Dyno or Dragy). Temped to look at this for my car but I do a lot of trackdays so want to make sure it's 'safe'. Thanks - Jonny |
10-09-2021, 03:19 PM | #2 | |
45
Rep 54
I don't have a dyno test with OPF to compare . I think you can gain about 15 hp by eliminating OPF. Increase in exhaust noise is significant . I have installed an OPF elimination kit from Active Autowerke. On my wife's Mini Cooper S 2021, I installed Leib OPF Delete to eliminate OPF. It works 99%. No warning lights on the dashboard, no limp mode, but three times in 5.000 km I got error code 1A2810 (inefficient opf) that I deleted using JB4 that I installed. For me it's worth to delete OPF |
04-12-2022, 08:04 PM | #3 | |
Rep 11
Drives: BMW M2 Competition 2018 f87
I did every software reset/ OPF replacement via ISTA+ (according to their instructions) but to no avail. BM3 tuning is the only solution I guess. Did you solve your problem on the Mini? If so, what is the solution? Thanks! |
04-18-2022, 09:37 AM | #6 |
Rep 11
I really have no idea why mine doesn’t work. Installation was done correctly according to LEIB’s instructions. The OPF deleter was plugged in between the car and the sensors. ISTA+ done too. Dominik from LEIB isn’t replying my messages either.
04-20-2022, 01:50 AM | #7 |
Rep 11
04-20-2022, 03:00 AM | #8 |
65
Rep 43
Honestly I don't have a clue. Guys in workshop installed it, all I know is that it was huge pita because sensors are very hard to reach..
04-20-2022, 04:18 AM | #9 | |
Rep 11
I tried moving it close to the sensors, it seems to be working for now, couldn't 100% confirm. Thanks. |
04-21-2022, 03:34 PM | #10 | |
109
Rep 243
I didn’t want to leave it dangling, because I was afraid of rattling noises. |
04-21-2022, 06:58 PM | #11 |
Rep 11
05-30-2022, 06:09 PM | #12 |
Rep 10
Curious to hear if you have any updates on your car & the opf delete modules? If not, how did you deal with your issue? I installed catless downpipes and AA single channel midpipe on a friends m2c with the intent to tune it and remove the opfs and cats that way, 1000km later and some hard driving no cel or limp mode on his car. Figured I'd do the same on mine.
Just installed the same setup on my m2 but with the opf delete modules (since I'd already bought them) from leib but still get limp mode. Sorta worked the first day, limp mode once then did several hard pulls and drove a lot. Next day as soon as I touch the gas more than 50% it goes directly into limpmode... Frustrating. Thought these were plug and play, was a real battle to get those in and still no success... Appreciate your response. |
06-25-2022, 03:31 AM | #13 | |
Rep 11
Dominik from LEIB agreed to replace me with a new set of cables, and I had to purchase a “CAN MIL DELETER” from him. Reason being my particular exhaust system produced a very low back pressure which the cables can’t detect/clear it (I’m not very sure about this). With that being said, I STILL GET THE FREAKING ERRORS after replacing the cables and installing the CAN MIL deleter! I’m tired of replacing/retrying. It cost me a lot to ship to my place and paying the custom tax! I guess BM3 tuning is the only solution (for me). Thanks |
07-15-2022, 12:35 PM | #14 | |
Rep 2
I am off to a garage next week so that they can take a look. Leib said that I will need to buy the same CAN MIL thing to clear errors. "Good" to know that it didn't solve the problem for you. I am equally as frustrated as you are trying to sort out exhaust |
07-25-2022, 04:17 PM | #15 | ||||
Rep 10
After all the hastle and effort, I'm now very satisfied with how it turned out (shouldve went with bootmod3 from the get go butbut). Good luck to you, hope all works out well. |
