10-03-2021, 01:52 PM | #1 |
4425
Rep 4,109
Custom tires on factory wheels
Both of my F90 M5s and my last M8 used H&R lowering springs and wore custom Michelin PS 4S 295/35/20 rear and 285/35/20 fronts. My current M8 is lowered using KW HAS. I plan to upgrade the Pirellis it came with (they're noisy and they don't look as nice... weird, but true) but mostly, they're too small for my tastes at 285/35/20 rear and 275/35/20 front.
Two questions: 1. Has anyone else added larger tires on stock wheels after lowering with KW HAS? 2. Is anyone running greater than 10mm tread width delta front to rear (e.g. 275 fronts and 295 rear)? Thx. // also posted to M8 forum |
10-03-2021, 02:33 PM | #2 |
116
Rep 107
I'm on the Dinan HAS and am running 285-295. I had to do 12mm spacers to not rub instead of 15mm. I def like the look of the wider tire better.
I'm on the 20" 789m wheels |
limeypride4425.00 |
10-03-2021, 02:34 PM | #3 |
4425
Rep 4,109
10-03-2021, 02:38 PM | #4 |
4425
Rep 4,109
10-03-2021, 02:38 PM | #5 | |
477
Rep 359
https://f90.bimmerpost.com/forums/sh....php?t=1858152 Edit: looks like he did say there is minor rubbing in the rear with 3-4 people in the car |
limeypride4425.00 |
10-03-2021, 02:45 PM | #6 |
2274
Rep 3,300
Michelin made you Custom Tires to your spec????? That must have cost a billion dollars a tire???? JK...I know what you mean....."Non stock" not "Custom" LOL.
Mike
10-03-2021, 02:53 PM | #7 |
4425
Rep 4,109
10-03-2021, 03:49 PM | #8 |
116
Rep 107
I stuck with 35. I thought about doing 30. If I went 1 step wider I was going to do 30.
