09-29-2021, 02:42 PM | #1 |
Rep 80
Meth Kit for N55
Getting tired of running E30 and want to run a meth kit because I feel my car kind of feeling hesitant at the top end especially at the end of a WOT. Do I need a hpfp and custom tune for this? Or can I run a jb4 with my ecu flash?
2014 m sport 435i rwd fbo upgraded turbos VRSF Chargepipe, vrsf race fmic, and hi flow downpipe BMS aluminum elite intake Stage 2H 93 bootmod3 ngk Cold spark plugs oem ignition coils Vargas stage 1 upgraded turbo 92500 miles xHP stage 2 transmission tune |
09-29-2021, 05:27 PM | #2 |
174
Rep 461
You can run your ecu flash and have the jb4 operating as just a meth controller.
Set it to map 0 and meth to operate on all maps. I can't remember for sure but I believe its option 3 on the meth settings. Highly recommend it. Also recommend stage 3 with your xhp. Feel free to ask further questions. I have been running this set up about 2 years. You also have the option of using the bms flash as well. Not sure which would be better vs your 2h bm3. Would need logs to determine. BMS offers their flash for free for jb4 owners. Last edited by 435gc; 09-29-2021 at 05:36 PM.. |
09-30-2021, 08:33 AM | #3 | |
Rep 80
09-30-2021, 08:57 AM | #4 | |
Rep 80
09-30-2021, 03:31 PM | #5 |
174
Rep 461
I run the bms meth kit with the jb4 as the brain.
I run a ps2 powered 435i with the supporting bolt ons. Xhp stage 3 for daily driver is spot on good. Check this thread for more info: https://f30.bimmerpost.com/forums/sh....php?t=1802540 |
09-30-2021, 11:42 PM | #6 | |
Rep 80
09-30-2021, 11:46 PM | #7 |
174
Rep 461
I run as my daily driver:
VRSF Chargepipe VRSF 5" HD FMIC BMS Intake FTP TIC MST V2 Inlet Turbosmart Plumback DV Active Autowerke highflow catted DP BMS JB4 BMS PS2 Race Flash BMS Meth Kit with 3 gal stealth tank and dual #7 nozzles NGK plugs 0.22 XHP Stage 3 PS2 Last edited by 435gc; 10-01-2021 at 12:00 AM.. |
10-01-2021, 01:05 PM | #8 |
Rep 80
Nice I was wondering if I can run it for just cooling and benefits and not have to use a jb4 because I'm afraid the spray might malfunction. Also is the snow performance meth kit just as good as bms meth kit?
10-01-2021, 01:37 PM | #9 |
4368
Rep 7,620
