09-18-2021, 04:22 PM | #1 |
88
Rep 94
Seat/center console noises from hell
Who else has gotten the crackles to hell from the center console and seat touching?
I've already changed the seat frame, wasn't that. Now replacing the entire center console and adding felt tape on the inside…. Thankfully I have a dope service advisor and mechanic to just try everything… |
09-26-2021, 04:56 AM | #2 |
758
Rep 1,336
Welcome to owning an M2. This is a common issue where others have noted changing seat position and/or angle has helped.
Mine has done it from purchase.. if you find a fix let us know!
Previous Rides: 13' 135i, 08' 130i, 03' HKS Turbo'd 350z, Modded GC8 WRX, NA MX5
methkingM2C87.50 |
02-24-2022, 09:22 PM | #4 |
176
Rep 201
The buzzing noise from the dash bothers me more than anything else.
2021 M2C, HS, 6MT, ZED, 763M w/spinners, AA single, AA axle back, Turner High Kick, Turner shifter support, M pedals, honeycomb reflector delete, BC Racing DS series
GPGP226.50 |
03-12-2022, 06:52 PM | #6 |
203
Rep 126
Mine has it too, especially with my seat almost max down.
So i put my seat in a higher more uncomfortable position to make less sound. 11/april i have a appointment with the dealership.
@Rub1con76
methkingM2C87.50 |
04-18-2022, 11:27 AM | #7 |
88
Rep 94
My mechanic added felt all inside the center console. That along with new console I think did the trick. Also the change he made to the seat frame was helpful too. Not sure what of the 3 did the final trick. Good luck.
04-18-2022, 05:30 PM | #8 |
80
Rep 48
Drives: M2 Comp
I was having the same issue. Service rep said they put some sound deadening material and padding. So far so good. Then again with the AA EQ and Remus race I can't hear much. Lol
Rub1con76202.50 |
04-21-2022, 09:44 PM | #9 |
10
Rep 33
05-11-2022, 05:44 PM | #11 |
2354
Rep 4,254
ugh. Mine was fine up until a hot day and now it rubs like crazy. WTF. The fitment to the console is SO tight. I didn't have this problem on the OG M2.
///M Power
