What material is the intake manifold made of?
04-28-2006, 08:57 AM | #1 |
570
Rep 6,750
I was looking at the intake runners this morning. When you tap on them, they practically look like they're made out of plastic, not cast aluminum.
05-15-2006, 07:37 PM | #4 | |
570
Rep 6,750
05-18-2006, 08:36 PM | #7 |
156
Rep 10,411
leatherette
2010 AW e90 328i: 6 speed, Black Leather, Dark Wood trim, ZPP, ZCW, ZVP,ZSP, Nav, Xenon
BMW Performance CF Rear spolier and Gloss black grills 2008 Candy White MKV GTI 2.0T 6 Speed Manul Gone 2008 AW X3 3.0si: 6 speed Returned 2006 AW e90 330i: 6 speed Dinan Stage 1 Returned |
05-18-2006, 08:40 PM | #8 | |
570
Rep 6,750
07-02-2006, 02:05 PM | #10 | |
Twin Screw Jockey
Rep 6
Any suggestions on where I can try to get hold of an engine from a 330 or 325 with intake manifold and accessories? I need one for a "special" project Steve
Twin Screw Junky |
07-03-2006, 12:13 PM | #11 |
144
Rep 1,184
Stimpee,
That ECU is NOT going to take friendly to what you have planned, LOL. The manifolds are probably not extude honed, they are molded smooth in 2 pieces then either chemically or ultrasonically welded together. There is no more "smoothing" that can take place. They are plastic because it transfers less heat into the intact tract than aluminum. Also cheaper and lighter. |
07-03-2006, 06:53 PM | #13 | ||
2146
Rep 10,176
I remember another european tuner doing that as well. I just can't place the company. Btw.. Great sig! |
07-05-2006, 02:24 PM | #15 | |
Twin Screw Jockey
Rep 6
What could you possibly mean?!?!?!?!
Twin Screw Junky |
11-20-2018, 04:11 PM | #16 | |
Rep 10
I am very aware of how old this post is, but since it was never specified exactly what kind of plastic BMW uses I thought I would share this good read....
From the link below..... Quote:
stimpee did you ever find you a doner motor? |
Fritzer944.50 |
11-20-2018, 05:18 PM | #17 | ||
996
Rep 2,287
Noir883.00 |
11-20-2018, 11:54 PM | #18 |
3966
Rep 7,215
11-21-2018, 05:06 AM | #19 |
996
Rep 2,287
Look at this stuff, not cheap but they mention Manifolds
"Automotive / Transportation Applications: Ultem™ resins provide automotive manufacturers with a high performance, chemically resistant, thermally-stable, cost-effective alternative to metal that is strong enough to replace steel in some applications and light enough to replace aluminum in others. For applications like transmission components, throttle bodies, ignition components, sensors and thermostat housings," I don't think my printer can get hot enough to make this work. https://www.3dxtech.com/ultem-1010-3...ting-filament/ |
11-23-2018, 05:20 PM | #21 |
2440
Rep 4,331
I would give polycarbonate a go in a 3d printer.
it's thermoplastic. so technically after it's printed it should not melt before it burns. Print temperature is around 280C, and IIRC poly carb doesn't glass until 150ish. it's about the highest temp plastic that you can run through an average 3d printer, and won't require any kind of post heat like the metallic materials. Also it's way kinder to your nozzle and hot end. The metallic ones will wreck a standard hotend with the quickness. You've got to step up to a ruby nozzle if you're going to use the metal/reinforced filaments. |
