09-16-2021, 02:26 PM | #1 |
Rep 3
Washer fluid tank removal query
Hi all,
I've recently had an issue with my washer jets essentially dribbling. After doing research (loitering in the shadows of this forum, thanks by the way) and troubleshooting including an interim fix also noted on here that only worked for a day, I've come to the conclusion that it is indeed the plastic filter on pump that's got gummed up (some of the algae came back up the top up/inbound pipe when doing the interim fix). I've set about trying to use the information on the forums and further a field, but I can't get the fluid tank to come out of the wing no matter how much force I use. The tank is loose at the top after undoing the screw attaching it to the top of the inside of the wheel arch, as well as removing the screw tack for the actual fluid top up cylinder (for pouring actual washer fluid in) in the engine bay, it appears to be just stuck on the plastic L shape bit that goes into the wing metal work as per the picture below. I've even tried using a trim tool and tapping it with a rubber mallet on the L shape bit. I've only seen one video of someone removing the tank (bad angle and you only see the mechanics back) and multiple descriptions on threads suggest that it should just pull free in like a clockwise motion? Am I missing something simple here or can someone please give assistance? Also on a 4 series do you know if you need to remove the plastic vent like bit (black plastic on left of pic with screw hole for the arch liner) that is attached to the wheel arch (that flows to the Air vent on the wing) to get enough space to remove it? Hopefully if there's an answer then if someone in the future looks, they can find the answer as my googlefu skills have struggled with the above. Thanks. |
09-17-2021, 02:48 PM | #3 | |
Rep 3
Any chance you have a copy of the PDF for the Preliminary task "Remove front right wheel arch cover" that you highlighted that you could share as well please? As it may show how the vent thing/bit on the left of my picture above is removed, if it even needs to be. Of course the tarted up coupe with side vents has to be more difficult than a standard saloon. Ha. |
09-17-2021, 02:55 PM | #4 | |
809
Rep 1,911
David2490.00 |
09-17-2021, 03:26 PM | #5 | |
Rep 3
Yeah, I could see they were from newTIS, I tried finding an archived copy of newtis earlier before asking you again as they look like a really handy lot of documentation to help with any future work needed, shame BMW got them taken down and added the subscription cost. |
