09-07-2021, 04:41 PM | #1 |
2418
Rep 1,361
Drives: 981CS/428/is250/JLU Rubicon
what to expect to pay for front brake job?
local dealer quote was over $1000 for pads and rotors
my local indy guy quoted me $717 might just order the parts and try to DIY with a friend |
09-07-2021, 05:02 PM | #2 |
76
Rep 128
Are you decently handy? You will save a ton of money DIY. Front brakes are fairly simple to do and there's 100's of great YouTube tutorials.
09-07-2021, 05:12 PM | #3 |
8273
Rep 16,136
You can do your own for $300 or less, and that's if you need rotors. Rotors usually last at least through two sets of pads.
09-07-2021, 11:07 PM | #5 |
108
Rep 187
If you're slightly OK with following directions, YouTube and a trip to the auto parts store will save you a ton of cash. I think the brakes on my f36 are the easiest I've ever had to work on and I've done brakes on a dozen different cars. If you're only doing pads, you can change them out in 15 min a wheel if you're quick! Even removing the calipers to swap rotors is very very straightforward. Order parts on FCP and one set of brakes will last you the life of the car.
On my last f36, Zimmerman rotors and Akebono pads, sensors and all were under $800 for all 4 corners. Dealer wanted $2200. Whole job was done, cleaned up and bedded in under 3 hours. |
09-08-2021, 12:42 AM | #7 | |
4531
Rep 5,396
Drives: 2015 BMW 335i x-Drive Auto
If you are looking for high quality rotors at a reasonable price then get Zimmermann German made plain rotors. If you want a rotor upgrade too then get StopTech full Crossdrilled. Best bite when combined with Hawk 5.0 pads. Also excellent in rain. |
09-08-2021, 12:44 AM | #8 | |
2418
Rep 1,361
any go to online sites for good price and fast delivery? |
09-08-2021, 06:14 AM | #9 |
417
Rep 919
I have always used OE compound pads, like Textar, and any blank rotor that isn't the cheapest...and have used FCPEuro for parts for close to 20 years. Lifetime warranties--some 'frugal' owners even return their used oil and get replacement.
Wgosma809.00 |
09-08-2021, 07:35 AM | #10 |
368
Rep 327
I also echo the others. Get yourself the parts, follow some tutorials, and make it a bonding thing w/ a friend (or my father in my case). Front brakes are typically easier because you can leverage turning them to access the caliper bolts more easily. The rears are the ones that usually get you but if they're not super rusted out or something, you'll be able to break them free without too much difficulty.
09-08-2021, 07:57 AM | #11 |
1471
Rep 975
Just DIY'd my front brakes last year for about $300 using Mayle blanks with OEM BMW pads. These are the base brakes though. It was quite easy (brake design is similar if not identical between auto makers) especially with an electric impact & ratchet.
Usually, the night before, I put the car on jack stands, remove the wheels and spray PB blaster on caliper bolts. That way, the next morning, it's cake. And yes, $500-$700 (indy) $800-$1000 (dealer) is normal for brake job with parts and labor.
15' 435i F33 Metallic Grey/Dakota Black/Contrast Blue | AWD | M Sport
15' 328i F30 Mineral White/Dakota Saddle Brown | AWD | Luxury Line |
09-08-2021, 08:18 PM | #12 | ||
4531
Rep 5,396
09-09-2021, 07:59 AM | #14 |
368
Rep 327
I haven't specifically changed a F3x's brakes but are you talking about the pad sensors? New brake pads come with a sensor and you just disconnect the old pads and reconnect them as you install the new ones. There would be an existing harness to connect to at each wheel.
09-09-2021, 08:46 AM | #15 |
86
Rep 174
Drives: 2014 F32 435i xdrive 6 speed
09-09-2021, 09:07 AM | #16 |
2034
Rep 2,815
Drives: F33 430 and F39 M35i
been awhile since I did brakes on my f33. isn't a sensor wire $11? just get a new one.
09-09-2021, 09:25 AM | #17 | |
368
Rep 327
tbh, I question whether they ever worked. |
09-09-2021, 11:05 AM | #19 |
725
Rep 943
Drives: F30 328i Msport
He absolutely did give a tip .
As for the OP's question, I did my msport brakes for 600$ all in, OEM two piece msport rotors front and back+pads+DOT4 LV brake flush. It pays to shop around for a little bit. Dealer had quoted a little under 3k$ for a brake job for my car. |
09-09-2021, 12:26 PM | #21 |
1471
Rep 975
Depends if they've been triggered. If you see the red brake error with the mileage countdown, its too late. Otherwise, if you are careful you can pry them off from the old pads and reuse. But @ $10, might as well replace them. Would suck to button up the car and you can't reset the pad warning.
