Tyre Pressures
11-11-2008, 09:02 PM | #1 |
8
Rep 131
Tyre Pressures
My back left tyre went from 3.20 bar to 2.40 bar again after new tyres, and with no evident sign of a puncture having said that BMW Battersea said I had two nails in my tyres before, even though I didn't check myself.
is this just air loss or should I get the alloy looked at ? gonna go take it to my mates garage to see if he can spot the puncture, after that Im all out of ideas. |
11-11-2008, 10:49 PM | #2 |
Moderator
322
Rep 5,493
You'll have to get the tyre looked at in the first instance, as you may have picked up another puncture (which would be horrible luck). The way to check is to get a solution of fairy liquid and water, and squirt it on to the tyre tread (do it in sections). If the solution starts bubbling away, that shows that air is leaking out in that particular spot. If there is no air leaking on the tread surface, then try the same thing but this time around the edges of the outside and inside rim. Easiest way obviously is to take the wheel off the car.
Good luck!
... ... DMS Remap Review ----- Quaife LSD Review ----- Hartge Antiroll Bars Review ----- Bilstein PSS10 B16 Ride Control Review ----- Detail by ShineOn ----- Paintshield Review |
11-12-2008, 01:56 AM | #3 |
1394
Rep 8,081
Have you got 225M wheels?
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
11-12-2008, 06:04 AM | #4 |
31
Rep 468
Drives: 2007 335i coupe
Tyre Pressure loss
Hey guys,
Ditto same issue, I loose air on all of my wheels and it goes down a bit if I havent driven the car for a while i loose air all around. I have the same 5 spoke (porsche looking rims, that came oem with the car) , but with these tyres : Rears are: 265/30ZR19 Conti Sport contact 3XL (filled to 41psi) Fronts are: 235/35ZR19 Conti Sport contact 3XL (filled to 36psi) First of all are these air pressure measurements correct ?, i tend to loose about 2-3+ psi per wheel every week or more
11-12-2008, 07:17 AM | #5 |
42
Rep 379
That sounds an awful lot. Perhaps a stupid question, but are you sure you're losing pressure on all tyres? Pressure can vary that much if the temperature's different between measurements - say from coming back from a run (tyres warm) to stone cold early morning (v.cold).
Having had my tyre pressure warning light come on recently, I'd happily pay extra next time for a real TPMS that could display tyre pressures in real time to save having to find somewhere to stop, get out and get wet and filthy checking tyre pressures manually.
2018 G30 520d M Sport with M Sport Plus - Mediterranean Blue
Previously: 2015 F32 430d M Sport, 2012 F10 520d M Sport, 2009 E92 320d M Sport, 2006 E92 335d, 2004 E60 530d, 2000 E39 525d, 1997 E39 523i |
