08-30-2021, 05:14 PM | #1 |
Rep 20
Help me with loud ventilation
I think my ventilation is too loud, but the dealership says it's normal. Could someone double-check my measurements?
In my garage, windows up, ventilation in manual mode with A/C off. Measurements taken with the Noise app on my Apple Watch. Off: 32db 1 bar: 43db 2 bars: 47db 3 bars: 49db By comparison, my 430i: Off: 32db 1 bar: 35db 2 bars: 37db 3 bars: 42db If you have an Apple Watch and an 8, would you mind repeating this test to see if it's really to spec? |
08-30-2021, 07:25 PM | #2 | |
254
Rep 271
08-30-2021, 08:06 PM | #3 |
Rep 20
It seems way too loud and isn't putting out an unreasonable amount of air. I'm running it in manual mode so I don't think the default intensity would impact that but I will check that setting.
08-30-2021, 09:48 PM | #4 |
641
Rep 628
Drives: 2019 BMW m850i Coupe
JustTony I'm travelling so do not have access to my car otherwise I would send photos. I had the same issue. I rectified this by de-selecting the 'indirect' box in the air-cond/ventilation settings.
Indirect reduces the output to the main vents and pushes air to other places. You therefore need to crank up the air output to get the desired heating / cooling effect. This creates more noise. Try this and see if it makes a difference. |
Van_bimmer110.00 M8Bimmer1284.50 |
08-31-2021, 06:24 AM | #5 |
Rep 20
I figured out a workaround for anyone else annoyed by the fan noise.
Indirect mode was on (thanks for that tip) but turning it off didn't make a huge difference. Turning off Auto mode on the rear climate controls greatly reduced the noise, dropping from 43db to a totally reasonable 35db. I don't usually have anyone in the backseat so I set it to manual and low speed fans. In the Climate Control settings, under Second Row Of Seats, clear the checkboxes for Default Setting and Automatic. It's probably a design flaw... The fans are probably underpowered for the GC model and so they have to work way too hard to push air to the backseat. |
08-31-2021, 09:16 AM | #6 | |
1923
Rep 2,012
Drives: 2022 i4 M50
One of my favorite features over the last couple of generations in BMW cars has been the ability to adjust the fan speed while in auto mode. In the previous gen cars, like your F36, that fan speed was absolute based on the number of bars you set even in auto mode as it would just adjust the of the air coming out of those vents independent of the fan speed to keep your set temperature. Very simple and straight forward. It still does this now, but the fan speed setting is more of a relative setting to let the system be more efficient. You'll notice that as the car gets up to temp in auto mode the fans will still start to slow down, especially when the sun or outside temperature difference isn't as great. What you had set to 3 bars might scale down to what you would expect for 2 or even 1 bars once this happens. When I drive at night during the summer, I actually have the opposite problem you describe. I like to have cool air in my face regardless of the season, so I'm putting the now digital slider to blue and the fan speed all the way up while in direct air flow mode. I simply can't get the system to keep blowing hard enough without turning down the temperature further and further throughout my trip. Driving during a hot sunny day is as you describe, it's really magnified in my X7 because there's a rear passenger vent in the B pillar right next to my ear. I end up closing those vents and also turning up the temperature to slow down the fans more because setting to 1 bar is too loud at times as you describe. Basically, the "auto", while likely more consistent and efficient, just doesn't seem as "auto"/hands-off as it used to be. I would expect you would get very different measurements after a 20 minute drive at night given like settings. Where I used to keep the cabin temp at 72 all the time while simply adjusting the fan speed where I see fit depending on the situation, I now see myself turning the temp down to 68 with 4 bars when I need more airflow without going to max, or up to 76 with 1 bar when I desire the opposite.
Current: 2022 i4 M50 | 2022 G07 X7
Gone: 2020 F92 M8 | 2020 G07 X7 | 2018 F80 M3 | 2017 F15 X5 | 2016 F16 X6 | 2015 F36 4 series GC Last edited by unfoundnemo; 08-31-2021 at 09:36 AM.. |
08-31-2021, 02:33 PM | #7 | |
4334
Rep 4,389
Drives: 2020 M850i Coupe
07-08-2022, 01:43 AM | #8 | |
Permanently confused
1171
Rep 1,708
Lots of noise for little effect….. |
07-08-2022, 09:43 AM | #9 | |
733
Rep 379
Backseat ac noise is common in many vehicles. My suburban screams if I turn on the rear ac, which fortunately I almost never need…if you think that’s noisy, wait until you turn on in seat cooling…. |
07-08-2022, 12:24 PM | #10 |
3493
Rep 3,214
I cannot hear -- or feel -- anything from my ventilated seats. They're probably working as designed, but it's something I'll ask about on my first service visit.
CURRENT: '24 M4C Conv
RETIRED : '23 M8C Conv | '20 X4 M40i | '18 M4 6MT | '13 M5 6MT | '08 550i 6MT | '04 545i 6MT | '98 540i 6MT | '94 530i 5MT | '84 528e 5MT Other retirees from Chevrolet, Buick, Subaru, Honda, Acura, Merkur(!), Volvo, Saab, Audi and Porsche |
07-08-2022, 12:32 PM | #11 |
4603
Rep 3,546
Use a tissue it will pull into the top of the seat if they are working. The system acts like suction not blowing.
2022 M8 Comp Convertible
2023 718 Cayman GTS 4.0 2019 718 Cayman Base 2015 M235 Manual On the list for the M2 CS |
hinckley3492.50 |
07-08-2022, 12:39 PM | #12 |
3493
Rep 3,214
Great idea. Thanks. And ya, I'm aware that the concept is to suck damp air away from your body rather than blow cool air onto it, like most American cars do. Frankly, a/c (and plumbing in general) is one of those things that Americans get better than ROW.
07-08-2022, 02:57 PM | #13 |
1292
Rep 1,658
Check to see if the vent on top of the dash is open/fully open, this will take some pressure off the other vents while also helping to distribute the air around the windshield area where most of the heat comes into the vehicle.
2019 M850i xDrive Coupe (06/19 Production)
Mineral White/Black, HP Cooling/Tire/M-Technology Pkg/Extended Shadow/Etc., Anthracite Headliner, Carbon Roof, DAx2, Display Key, Various Accs'. Topic permitting, I try to be objective as possible |
