08-30-2021, 09:45 AM | #1 |
3906
Rep 3,127
NEW RELEASE: Dinan F90 M5 Cold Air Intake & Turbo Inlet Pipes
Featured on BIMMERPOST.com Dinan F90 M5 Cold Air Intake & Turbo Inlet Pipes Part Number: D760-0049 & D760-0053 Applications:
Product Page(s) / Pricing: Cold Air Intake: dinan.info/F90-M5-CAI Turbo Inlets: dinan.info/F90-M5-TIP Release Date: Available Now! Description (Cold Air Intake): The M5 is the flagship of the marque and as such deserves to showcase the best possible components. The Dinan Carbon Fiber Cold Air intake for the latest generation of M5 holds true to that philosophy and offers arguably the best performing and most efficient sealed intake solution on the market. Quite possibly the most visually impressive as well. The first thing noticed upon gazing upon the engine bay equipped with the Dinan intake is the sheer amount of gloss UV coated 2x2 carbon fiber. Stretching from one end of the engine compartment to the other, courtesy of a fully functional secondary air inlet wishbone, the material is not only beautiful to look at but serves the purpose of heat deflection as well. The wishbone, which mimics the equally impressive calling card of the F8x M3/M4 engine compartment, is purposeful in a different way. Instead of adding structural integrity, the wishbone serves as the conduit for a secondary air source deriving its contents from a central hood scoop located behind the front grilles. The additional air flow supplements the factory inlet locations on both the left and right air boxes with ambient air from outside of the engine compartment. These air boxes have been enlarged and equipped with massive filters to handle this increased volume and together with the rest of the system allow the intake to flow as efficiently as possible. While the stock intake system is adequately suited to support up to stage 1 power levels that does not mean there is no performance benefit when upgrading to the Dinan system. Besides its amazing appearance the biggest advantage of the system, by virtue of additional and optimized flow, is the reduction of the pressure depression in the stock system. This equates to the turbo having to work less in order to achieve targeted power. With the turbo working more efficiently this also means a lower pre-turbine backpressure, lower turbocharger shaft speeds, lower turbocharger compressor discharge temperatures, and for the ability to achieve higher boost pressure levels. Coupled with the optional Dinan Turbo Inlets these effects are even more exacerbated and represent ideal optimum flow and efficiency. Paired with the natural improvement to throttle response, a minor bump to the acoustics, and a visual appeal that will leave anyone speechless the Dinan F90 M5 carbon fiber intake system is a perfect complement to the "best." Features/Benefits (Cold Air Intake):
Description (Turbo Inlet Pipes): The Dinan Turbo Inlets are an easy-to-install bolt-on upgrade that eliminates the largest obstacle in the entire factory intake system, the turbocharger inlets themselves. They are an upgrade that is both cost effective and an important stepping stone in the modification journey to unlocking maximum power out of the luxury sedan. From the factory, the plastic inlets are limited and allow very little volume to pass as they neck down dramatically to the turbochargers themselves. This reduction stifles flow and increases the pressure ratio pre-turbine causing the turbochargers to work harder than necessary. This is a problem Dinan engineers took great care in rectifying through exhaustive prototyping and testing to ensure maximum future power potential while also having compatibility with numerous potential configurations. The benefit of their hard work are Dinan Turbo Inlets that are constructed of gloss UV coated 2x2 carbon fiber and are designed to mate seamlessly with whatever level of modification to the intake system you anticipate (paired with either stock air boxes or the full Dinan Cold Air Intake System). Where the carbon fiber ends an aluminum adapter to connect to the stock turbocharger begins. Using the same factory locking system, installation in this area is straightforward and earmarked by a "click" when secure. The simplicity making this quite possibly the quickest and least aggravating installs on the platform you will encounter. The pipe itself has been created to offer the largest possible cross-sectional area all the way from the intake filter to the turbo, a staggering 200% increase in volume over stock. This is the key to maximum performance gains from the system and the reason for the organic and unorthodox shape of the Dinan inlet system. While the effects of the additional volume are pronounced on a vehicle equipped with the factory airboxes and results in average gains of +11 WHP / +13 WTQ from 2000 RPM to redline, the overall efficiency of the entire intake system is maximized when paired with the Dinan Cold Air Intake that is also delivering an increased volume of cooler air earlier in the intake tract. Robust testing with a fully instrumented engine further illustrated the multitude of benefits the Dinan Turbo Inlets offer beyond the confines of the dyno room and flow bench. Simply put, the F90 M5 / F9x M8 Dinan Turbo Inlets assist in allowing the turbocharger to operate at a lower pressure ratio, which means it will operate more efficiently. This directly translates to lower pre-turbine backpressure, lower turbocharger shaft speeds, lower turbocharger compressor discharge temperatures, and for the ability to achieve higher boost pressure levels. Features/Benefits (Turbo Inlet Pipes):
08-30-2021, 12:22 PM | #4 |
3906
Rep 3,127
Assuming you are referencing the inlets? The bullets points above for the inlets are with that configuration (stock intake, Dinan inlets) so additional flow, more power, etc.
08-30-2021, 02:03 PM | #7 |
3634
Rep 875
Drives: ///M2
Will these be CARB legal?
N54 135i 6MT (FBO, JB4 reflash, E30) sold
E90 M3 DCT (FBO, tuned) sold Current: Performance Edition M2 6MT (FBO, ethanol tuned by Bend Calibration/Ecutek) |
08-30-2021, 02:14 PM | #9 |
273
Rep 647
Seems like pretty clever design to take in air from the top like that.
Do you have any plans to also develop new lower filter boxes and intake pipes with scoops? Or are the stock ones good enough? |
08-30-2021, 02:58 PM | #10 |
3906
Rep 3,127
That's the ultimate goal but its still a VERY fuzzy picture when it comes to removal/replacement of the factory hydrocarbon filters. CARB does not have a test for them yet so no intake that gets rid of them will be able to be CARB approved. We have integrated a carbon liner as our own solution to replace what the hydrocarbon inserts did (have used this method since the F10 M5 intake on affected platforms) and that is in the process of potentially being a approved solution. However, it all comes down to what CARB does for a test that currently does not exist.
No plans to. There is no gain in real estate (volume) by replacing the lower boxes so it would just be adding cost unless you somehow integrated a secondary air inlet on the bottom but thats what the top scoop is for so to do both is a bit overzealous. Truth is the stock intake/configuration flows enough air to support up to stage 1 power levels. The main purpose of the intake is the optimization of that flow and getting the pressure as close to ambient as possible to reduce workload on the turbos for a more efficient system. Now if you are planning on building a 1000+ HP monster, then yes, the intake does flow more to support those numbers. However, the vast majority of folks that will make no difference for. |
08-30-2021, 03:23 PM | #12 | |
273
Rep 647
08-30-2021, 03:37 PM | #13 |
3906
Rep 3,127
08-30-2021, 08:54 PM | #15 |
///M Specialist South Shore BMW
770
Rep 7,108
Wow that is a gorgeous piece. Very eager to try this piece and it looks like you guys really took your time to do this right and make it a very worthy mod. Great job guys.
2021 M5 COMPETITION LCI Brands Hatch Gray on SIlverstone, carbon roof, comp wheels, Mperf splitter, carbon pro spoiler, carbon diffuser , carbon paddles, executive pkg. Dinan HAS, RaceChip, dinan spacers, FC stud kit, etc
08-30-2021, 10:06 PM | #17 |
213
Rep 548
08-31-2021, 02:57 AM | #19 |
87
Rep 315
Wow you guys are doing a e30 tune as well? Remarkable stuff ! And I’m assuming even using your inlet pipes with other tunes would be a good gain as well
08-31-2021, 09:45 AM | #20 | |||
3906
Rep 3,127
On the inlet product page is where you can find the performance graphs. The CAI on its own after adaptation has no meaningful power gains hence why no chart is included. Quote:
Inlets would work with other intakes (assuming the same mate point which is not always the case) and tunes just fine. |
Slugsy01157.00 |
08-31-2021, 11:36 AM | #22 | |
3906
Rep 3,127
Now how about that intake... <insert ooo's and aaaah's> |
MilehighM3915.00 ndkicker31.50 |
