08-28-2021, 07:26 PM | #1 |
356
Rep 689
Drives: 22 TR X3MC
Stumbling on load
So long story short, I just recently got my transfercase replaced because the car was stumbling and my mechanic said it sounds like it's the transfer case. It was making some kind of mechanical noise. After changing it the the car continued to stumble and the calibration kept going out -14 degrees. It was also throwing a temporary transfer box temperature code as well. The guy I bought the transfercase from then recommended me to change the transfer case actuator which I might pick up from him on Monday. For the time being I decided to turn xDrive off and later came to find out the car stumbles but not as bad as with xDrive on. I took some logs and the logs show that the cars running fine so I'm completely lost at what it is.
2022 X3M Comp
2013 335i xDrive (Sold) Last edited by redbullfan; 08-28-2021 at 07:38 PM.. |
08-29-2021, 08:10 AM | #3 |
356
Rep 689
Drives: 22 TR X3MC
When calibrating the vtg you're supposed to calibrate it to 0. After going for a drive and getting on load the car stumbles and the vtg calibration goes to -14.5 which is not good. I also get a code for the transfer case temp being to high
2022 X3M Comp
2013 335i xDrive (Sold) |
