08-12-2021, 05:54 PM | #1 |
Rep 29
How to add a sub to the harman kardon?
Hi
I replaced my HK with bavsound speakers, they sound amazing. I couldnt find an amp upgrade too bad cuz it would sound even better. Any tips or tricks to add a subwoofer to the car? Is it possible to relay a 2nd amp after the harman kardon amp? Thanks |
08-12-2021, 06:22 PM | #2 |
Z
46
Rep 131
08-12-2021, 07:09 PM | #3 | |
Rep 29
I see someone even put an amp for the speakers. My question is more like, is there an RCA out off the H&K amp, just need to know how to plug and if doable.. i guess it is doable just dunno how.. Shop prolly knows |
08-18-2021, 06:47 PM | #5 | ||
578
Rep 648
09-01-2021, 08:14 AM | #6 |
11
Rep 44
I have b&w also running a JL audio 12" w6 in a HO box. The front end has been changed from B&W too. They used a bit dmi or a Zen integration module can be used. Or as above take a feed from the speakers & use a loc to run rcas into your amp (won't sound as good imo).
09-13-2021, 02:13 PM | #7 |
Rep 7
I am in the process now of adding a sub in my 19 M5 with Harmon Kardon audio systems. Planning on running a JL Audio 12W7E in a Pro Wedge Box that will sit in the trunk and I will run a remote audio knob near the driver seat for bass gain. Technicpnp make a connector cable that is plug-n-play and gives you the Sub wires out that can plug in a LC2 Line output converter. Adding a JL Audio RD 1000/1 behind the driver side panel above the factory HK amp it will be all hidden and look pretty. Can add some pictures once it's all completed.
Technicpnp BMW Connector AudioControl LC2i PRO JL Audio RD1000/1 (PDF) JL Audio 12W7AE |
Jamesmick131.00 |
