BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > f20 118d fault code and 02 sensor help??
      08-05-2021, 10:53 AM   #1
sps
sps
United Kingdom
12
Drives: x3 f25
my car is bmw118 d se f20 facelift 2015 model -build date june 2015,and the engine code is B47
it came up with the following fault codes and there is no EML light on
Fault code: 284E00 Lambda probe according kat, nernst voltage signal: interruption
Fault code: 283400 Lambda probe according kat, controlling heating: interruption
Fault code: 282E00 Lambda probe after catalyst, triggering heating: short circuit to positive
i am confused as to which lambda or 02 sensor is faulty and needs replacement.
      05-09-2022, 12:31 PM   #2
sps
sps
United Kingdom
12
Drives: x3 f25
Smile
i replaced the post cat 02 sensor and cleared the fault codes.and it has resolved the problem
      07-23-2022, 10:45 AM   #3
Ale900
Drives: Bmw118d
Guarda ho il tuo stesso errore e sto cercando di capire quale fosse il sensore… per caso ricordi il nome o hai una foto?
      07-24-2022, 06:16 AM   #4
sps
sps
United Kingdom
12
Drives: x3 f25
the sensor BMW part number is 13628589104.
it is called the post-catalytic or the after catalyst oxygen sensor.
i hope this will help you
      07-24-2022, 11:39 PM   #5
Ale900
Drives: Bmw118d
Da ricerche che ho fatto era quello secondo me… con te ho avuto la conferma… grazie mille
